Old 12-13-2004
sailnaway is on a distinguished road
Electrical draw problem
When I turn my Shur Flow water system on the lights dim and then flicker as the system comes back up to pressure. This system has a dual filter and a pressure tank so at the end of each pump cycle it works fairly hard to pressurize.I would like to know if I go to a larger wire size will this go away or is it a common problem I should just deal with. Do you think this is a drop on the whole board or what. I gusee it would be if it causes the cabin lights to dim.Could it be all the way back to the batteries and should I put a meter on to see if it is. ?????
Old 12-13-2004
dameware is on a distinguished road
A better way to find the voltage drop in the system, rather than using a meter, would be to use a 12 volt bulb and 2 wires as it might be easier to “see” the voltage fluctuation using light rather than a meter.
I would start at the battery bank and head toward the pump’s circuit on the electrical board.
If the light dims when the wires are across the battery bank, the bank may be too small for the size of the pump – you would have to look no further.
If the light doesn’t start flickering until you get into the electrical panel, then there’s a “voltage bottleneck’ in there somewhere.
If that is the case, look for a corroded connector where the +12 bus connects to the battery bank switch.
And also look for any wiring modifications in the panel – a too small wire could also be a problem, as you pointed out.
Good luck!
Catalina 34 Starting Battery Problem Garytami Gear & Maintenance 6 03-06-2010 11:33 PM
Funny Electrical problem Bruceo1 Gear & Maintenance 2 12-15-2003 06:01 AM
Electrical Upgrade keitha Gear & Maintenance 25 04-11-2003 12:38 PM
1981 Honda 9.9, 4 stroke o/b, Idle problem randj65 Gear & Maintenance 4 06-19-2002 10:59 AM
Engine Oil Pressure Problem msamelso Gear & Maintenance 2 02-20-2001 06:25 PM
