Particulate residue in Racor bowl - SailNet Community
post #1 of 1 Old 12-02-2013 Thread Starter
grandcapri's Avatar
Hello, mostly new here...anyone willing to chime in on fouled Racor water separator bowl. Winterized yesterday and as is normal routine, I replace both primary and secondary fuel filters (and fuel lift filter as needed), I took off the primary filter, bowl connected, and notice excessive amount of freely floating tannish particulate matter in the bowl and a coating of residue on the clear part of the bowl. It is not black, or sludge like in appearance. And the boat shows no symptoms of fuel issues while underway. Small amount of white smoke upon start up after a week or so of non use, but clears up quickly. I regularly use biocides, fuel cleaner and water dissolver.
I'd be interested in hearing from someone and I apologize up front if this topic as been discussed to death.
grandcapri is offline
Clean up the residue from butyl rubber? Hudsonian Gear & Maintenance 5 04-17-2012 03:11 PM
remove 3M tape residue from topsides & interprotect gallilaw Gear & Maintenance 15 05-16-2011 03:02 PM
Why is there white residue on my deck? saurav16 Gear & Maintenance 5 05-25-2008 08:07 PM
How to Remove nasty glue residue from headliner? gratefulsailor19 Gear & Maintenance 4 02-07-2007 01:26 PM
