Prop shaft alignment - SailNet Community
post #1 of 2 Old 12-03-2013 Thread Starter
I recently installed a rebuilt engine and replaced the motor mounts. I realigned the shaft/transmission coupling. I had the boat (Catalina 25 WK) on the trailer. I have since put 6 hours on the engine and the vibration increased. Last week the boat was in the water so decided to re-look at the alignment of the shaft/transmission coupling. I could not get everything to align correctly. I then took a dial indicator to check the run out of the parts. The shaft and its coupling were within two thousands. The transmission coupling ears were out to each other over thirty thousands fore and aft. I built spacers to compensate for the mis-alignment and spent a couple of hours re-aligning. It is now smoother that it has ever been. Was worth the time and effort.
H and E is offline
post #2 of 2 Old 12-03-2013
Maine Sail's Avatar
Re: Prop shaft alignment
Sounds like someone used the gearbox coupling to press off the shaft coupling..... One reason I very often advise cutting the shaft as opposed to using an expensive gear as a press tool..
This will make future alignments very difficult if not impossible. The shaft coupling should have almost no run out at all and should be properly fitted to the shaft then "faced".... If you have the space a flexible coupling such as a Bull Flex may be your only option..
______
-Maine Sail / CS-36T
Maine Sail is offline
Shaft Alignment: Alignment causes mount problems lizardheadone Gear & Maintenance 12 11-24-2013 09:29 AM
2GM20F Shaft Alignment... mm2187 Gear & Maintenance 5 04-11-2013 09:29 PM
Shaft alignment with a dripless seal Downunder Gear & Maintenance 6 05-11-2010 03:30 PM
Proper shaft alignment Joshua Dawn Gear & Maintenance 20 12-13-2009 04:17 PM
Prop shaft alignment Jotun Gear & Maintenance 9 02-23-2007 10:13 PM
