dye a spinnaker?? - SailNet Community
post #1 of 3 Old 12-16-2004 Thread Starter
dye a spinnaker??
Is it possible to color a white spinnaker with colored dye???
maestro is offline
post #2 of 3 Old 12-16-2004
RichH's Avatar
dye a spinnaker??
Absolutely not!!!!! The dye thats in the nylon filaments is added before the fiber is formed. There is NO way to dye nylon after its formed/made.
If you attempt to dye nylon yourself all you''ll do is a temporary coating to the nylon filaments; and, these will wash off, wear off ..... the result will look worse than SH*T.
The only way to add dye to nylon is by a process called ''thermo-soling''; but, you need high temperature steam filled precision rollers and very special dyes ... something that a ''consumer'' cant do.
Sorry, but dont even THINK about throwing a spinnaker in a wash tub filled with "RIT" or other dyes that you buy at K-mart, etc. Consumer ''dyes'' are only for ''natural'' fibers: wool, cotton, flax, etc. ... NOT for synthetics.
RichH is offline
post #3 of 3 Old 12-16-2004
dye a spinnaker??
I''ve heard of sails being painted with Acrylic with good results.
jimthom
jimthom is offline
Flying an undeclared oversized jib as a spinnaker mikehoyt Racing 4 06-17-2004 04:49 AM
Flying a spinnaker on a dinghy jbr Learning to Sail 0 09-04-2003 08:52 PM
Spinnaker on Pearson 30 zeilfanaat Gear & Maintenance 4 07-22-2003 04:42 PM
Spinnaker Wrap Poll paulk Seamanship & Navigation 3 12-07-2002 03:19 PM
Using Assymetric Spinnaker from old boat RPerreca Gear & Maintenance 1 02-23-2002 03:01 PM
