Recognize this furler? - Page 2 - SailNet Community
 2Likes
post #11 of 20 Old 12-06-2013
Old as Dirt!
svHyLyte's Avatar
Re: Recognize this furler?
Originally Posted by chartscharts View Post
Got it....
I'll experiment more with sailing under main alone.
-Charts
Practice using your traveler to advantage. It helps. A Lot!
svHyLyte is offline
post #12 of 20 Old 09-25-2015
I have a 28' C&C designed Viking. This boat has the same Sterns Twin Stay minus the drums. I was wondering if you would think it wise to buy the durnafurl drum and related hardware to get this back to a fully functioning roller furler. All my head sails luffs are designed for this foil.
Any info would be appreciated. Thanks
ddiesel is online now
post #13 of 20 Old 09-26-2015 Thread Starter
I love the furler. I find it much easier to deal with raising and dousing the sail. My previous boat didn't have one. The one I have is old and clunky, yet it still works.
chartscharts is offline
The Following User Says Thank You to chartscharts For This Useful Post:
ddiesel (12-05-2015)
post #14 of 20 Old 09-26-2015
That headfoil was produced as a simple foil too, so I'm wondering if you can actually retrofit a drum. Do you have the halyard swivel/slider? Are your sails sized to match the luff length with the drum in place or are are they currently tacked to the deck? If the latter your sails will need cutting down assuming you can fit a drum and that the foil is designed to truly swivel.
I'm thinking it's not going to be as simple as adding the drum assuming you can find one...
btw.. we owned a V28 for ten years... great boat, pretty lines, good habits. Enjoy!
Faster is online now
post #15 of 20 Old 09-26-2015
Thanks for your response. I think I would rather put the money into this furler than dealing with modifying the sail luff and foil. Currently it only has the foil. I am going to attempt to attach some photos. Please give me your feed back. Thanks
post #16 of 20 Old 09-26-2015
Really not sure. Still learning about sailing and the boat. I am attaching a couple of pics. Currently I don't secure the foot of genoa, It is held at the top by the halyard. along the luff by the foil and at the clew by lines. Not sure pics will post I might have to keep playing with that. Thanks for your response
post #17 of 20 Old 09-26-2015
here's pics. Thanks
post #18 of 20 Old 09-26-2015
Yeah.. that's just a Stearns dual slot "headfoil".... not a furler in any sense of the word. This is not something you can 'convert' to a furler. It's simply meant to give you a smoother luff than hanks might, and to allow you to hoist a new (smaller or bigger) sail before you take the other one down (a racing advangtage). btw it's not the best foil out there by a long shot.
Your tack needs to be attached to the deck fitting somehow.. there should be a hook or a shackle or a pin to facilitate that. Otherwise you'll never get enough luff tension for a decent sail shape and performance will suffer. You can see the bow casting has two holes right behind/under the forestay/foil.. that's where your shackle should attach.
Honestly, even if you can't buck up for a decent furler I'd suggest you look into a newer, better foil (Tuffluff, if they still make it, is probably the least expensive) On today's headfoils both grooves face aft, a great improvement over the one you have.
Looks like Schaeffer makes the tuff luff still...
http://www.schaefermarine.com/our-products/tuff-luff/
ddiesel likes this.
The Following User Says Thank You to Faster For This Useful Post:
ddiesel (09-26-2015)
post #19 of 20 Old 09-26-2015
thanks you were a big help. I will have to research my options. I have to single hand the boat so I would like to get decent furling system. Thanks again
post #20 of 20 Old 09-26-2015
You're welcome.. another thing.. todays foils 'slip over' an existing wire or rod forestay. If I remember correctly your foil actually replaces the forestay, so if you do go to a real furler you'll need a forestay as well. (and at this age that's not a bad idea in any case.)
Harken, Cruising Design, Furlex, Schaeffer all make decent furlers, I think the Furlex comes with a new forestay as part of the package.
However you'll probably be looking at the better part of $2K by the time you're done, and you will have to shorten the luff of all your headsails to match because the new 'tack' will be on top of the drum, some distance off the deck.
Welcome to the money drain that is boat ownership!!! she looks nice and clean, btw...
Recognize this? deep blue Cruising & Liveaboard Forum 1 07-21-2013 10:03 PM
Anybody recognize this sweet boat? SoulVoyage Boat Review and Purchase Forum 8 05-22-2010 10:08 PM
recognize this boat? eleanor General Discussion (sailing related) 2 07-16-2009 07:13 PM
Recognize this Boat Stillraining General Discussion (sailing related) 12 06-03-2008 11:07 AM
Anyone recognize this burgee. orangebikemaker General Discussion (sailing related) 4 02-26-2007 09:43 AM
