Bulb for nav light - SailNet Community
post #1 of 5 Old 12-03-2013 Thread Starter
Bulb for nav light
Can anyone decipher the top of the Aqua Signal nav light in the image below and tell me what model this is? It is a bi-colored light. Does Dr. LED make a USCG certified bulb for this light fixture? Do I need a bi-colored LED bulb even though the lens is colored?
Thank you to anyone that can clear this up for me.
https://drive.google.com/file/d/0B10...it?usp=sharing
SteveInMD is offline
post #2 of 5 Old 12-03-2013
no longer reading SailNet
Alex W's Avatar
Re: Bulb for nav light
Aquasignal TD41 seems to mean it is one of these:
http://www.aquasignal.info/us/files/...0,41,42,50.pdf
BICOLOR SIDELIGHTS TD 40/41/50
Alex W is offline
post #3 of 5 Old 12-04-2013
mitiempo's Avatar
There is not a bulb that is certified by itself. There are only bulb/fixture combinations. Only if the bulb is certified with that exact fixture will it meet approval. None are approved, regardless of what the bulb manufacturers state.
This link shows a letter concerning this from Aqua Signal on post #4
LED Nav Light Conversion - Cruisers & Sailing Forums
Well worth reading.
Brian
mitiempo is offline
post #4 of 5 Old 12-04-2013
Yes, you most certainly need a red LED bulb behind the red lens and a green one behind the green lens. A white LED will barely show through a coloured lens. I had a local fellow make custom LED bulbs for my Aquasignal and it turned out very well- much brighter than the original and a better quality of light (very pure). If you're a bit handy, you can make your own replacement bulbs.
Vindö 50
copacabana is offline
post #5 of 5 Old 12-04-2013
mitiempo's Avatar
Just keep in mind that if there ever is an accident at night your lights had better be of the proper CG approved type or you could very well be held liable, regardless of who hits who. I sell Dr Led lights and would never recommend that their nav bulbs be used in a fixture that ends up not being approved as a combination.
The best solution is to buy an approved fixture that is Led. This is especially true of red/green lights. Steaming, anchor, and stern lights being white are less of a problem.
Brian
mitiempo is offline
Mast light bulb ScottyG24 O'Day 4 05-14-2013 01:23 PM
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 01:53 PM
Anchor light Bulb type? deniseO30 O'Day 3 05-22-2011 10:37 PM
Columbia Foredeck Light Bulb Hoofangler Gear & Maintenance 0 06-15-2009 08:03 PM
'76 Pearson 26 steaming light: what bulb? fendertweed Gear & Maintenance 12 05-20-2009 09:23 AM
