Testing antifreeze products - SailNet Community
post #1 of 6 Old 12-04-2013 Thread Starter
pdqaltair's Avatar
Starting a new reseach project; this will be a big one, out in phases for Fall 2014. A call for brands.
We have contacted:
* West Marine
* Camco
* Star Brite
We will include, in several different catagories:
* Vodka
* PG, EG, and alcohol based freeze proofing agrents
* Auomotive and heavy duty (diesel) products
We will be looking at:
* Burst Point
* Elastomer and plastic compatibility
* Value ($/freeze point)
* Bio fouling and taste
* Coorosion (potable and engine product will have separate test protecols)
Any specific brands? Any specifc questions to investigate?
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #2 of 6 Old 12-04-2013
Learning the HARD way...
eherlihy's Avatar
Re: Testing antifreeze products
I would throw Prestone 50/50 into the mix.
eherlihy is offline
post #3 of 6 Old 12-04-2013
billyruffn's Avatar
Originally Posted by pdqaltair View Post
Starting a new reseach project....
* Vodka
* Burst Point
Good luck with what sounds like an interesting project. But could you include "rum" in addition to "vodka" as it's usually more in stock on sailing vessels.
billyruffn is offline
post #4 of 6 Old 12-04-2013
Maine Sail's Avatar
We have contacted:
* West Marine
* Camco
* Star Brite
* Vodka
* Burst Point
Drew,
Would love to see you guys show what dilution does to both freeze and burst points in thin wall copper and plastics. I see LOTS of DIY winterizing failures caused by the dilution of -50 PG. Folks often shut down an engine when they "see pink" and this is often not enough to adequately protect a copper tube HX because it leaves what is in there rather diluted...
I test engine concentrations in customers boats with a sight refractometer until what comes out the back matches what came out of the bottle.. The next winter I know exactly how much she takes with no guess work. I think a lot of boat owners get lucky with the mild winters, but every winter that we hit 0F to -20F I know I will have freeze repairs in the spring..
I would add Wal*Mart SuperTech -50 RV and the Home Depot RV. Both are alcohol based. Those are the two I see most in the dumpsters each fall other than typical "boat brands". Don't forget Pahnol PG...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #5 of 6 Old 12-04-2013
Suggest samples are well marked if they find their way into
your freezer, as antifreeze will surely will resemble frozen Margarita
to the late night holiday guest...well maybe don't mark the Vodka!
HUGOSALT is offline
post #6 of 6 Old 12-04-2013 Thread Starter
pdqaltair's Avatar
Keep the feedback coming!
* Yes, Prestone will be in the mix, as well as some heavy duty brand. There are some that believe "heavy duty" in AF is just a sales pitch, but this is one product where it has a very specific meaning and the products are required to pass specific ASTM standards in order to be suitable for diesels with wet sleeves. For most boats using glycol cooling (since most are diesel) heavy duty products are more appropriate. Complicated topic.
* Rum. No, it is vile drink. Stout is far more civilized.
* Burst point testing. Mainesail is dead on; a focus will be under treatment, which causes bursting and... foul lines and tanks. Like alcohol, antifreeze is ONLY a sterilizing agent IF the concentration is over 25%. We will focus on PVC burst points because copper data is already well represented in the literature. However, there is another factor that many ignore at their peril; burst point numbers are only real if the glycol has not been separated by repeated freeze/thaw cycles (think about apple jack). I have seen pipe systems that were fine at the bottom but burst near the top; the water ice floats.
While we may not collect all of the brands, we can still generally get compositional information from MSDSs and other sources. For example, my local Home Depot carries Dowfrost RV, not their own brand, and Dowfrost is one I trust to be exactly what they say (premium brand I have tested before in my day job).
Automotive antifreeze vs. RV antifreeze for engine. dman535 Gear & Maintenance 18 09-30-2009 03:53 PM
Antifreeze harpguitar Gear & Maintenance 22 11-26-2008 01:42 PM
how much antifreeze? xort Gear & Maintenance 5 10-24-2008 07:11 PM
Antifreeze valdon34 Gear & Maintenance 2 07-18-2008 01:06 PM
antifreeze stm Gear & Maintenance 8 02-04-2004 02:53 PM
