Teak Veneer - SailNet Community
Blogs
Old 12-24-2004
nesailor is on a distinguished road
Teak Veneer
At some point in time the teak veneer was removed from the deckhouse of my vessel exposing a fiberglass surface which was subsequently painted. I want to replace the veneer. What is the best method for attaching the veneer to the fiberglass substrate?
Old 12-25-2004
paulk's Avatar
paulk is on a distinguished road
Teak Veneer
You will want to start by removing all the paint. Anything you stick to the paint will depend upon the adhesion of the paint to the fiberglass, which may not be 100% over the long term. Gluing the veneer to the paint-free deckhouse will likely best be done with an epoxy. The standard contact cement used with veneers will be too vulnerable to moisture in a deckhouse situation. After gluing the veneer to the deckhouse and then covering the exposed surfaces (especially the edges) with epoxy to preclude ANY water from getting near the teak, you will need to varnish the teak with as many coats as you possibly can. UV from the sun will cause the epoxy to turn dark brown, to the point you won''t be able to see the wood underneath it at all, unless varnish is used to protect the epoxy from the UV rays. (This is why cold-molded boat hulls usually end up painted. Keeping up with varnishing all the topsides all the time gets to be quite a chore.) The deckhouse should look nice when you''re done, though matching the grains of the veneers can be tricky.
Old 12-28-2004
DelmarRey's Avatar
DelmarRey is on a distinguished road
Teak Veneer
Don''t forget that teak is an oily wood. You may want to treat and primer the under side of the teak before epoxy-ing to the clean FG surface.
Proper primers are sold in marine supplies.
http://www.sailnet.com/store/item.cfm?pid=26898&searchterm=primer
Old 01-06-2005
sailnaway is on a distinguished road
Teak Veneer
you will want teak one side plywood exterior marine most of the over glass stuff was 1/4".
make tenplate on one side use door skin to do this as it will keep so you can flip it and make the otherside cardboard gets to beat up and will not hold up. I like to put white shelf paper on the teak side to protect the wood while I get it in place and glued down with a good epoxie glue with at an eight hour set time for strength. use allot of one by two to put pressure on as much of the surface as you can. Clamps around port cut outs and where you can clamp it down. Tight man thats how you want it and clean up the ooze right away don''t let it set up.Now do the other side the same way. Who ever said remove the paint was right on get rid of it. Ok now you have the clean wood in place and you did not leave the contact paper on for three weeks did you??? good don''t do that take it off as soon as the wood is in place or the heat and moisture will leave the glue behind and it is a real bummer to sand off.Now you have a clean and undamaged new teak cabin you can varnish three times a year thin that first coat real good so it gets in deep. Don''t sand to much or you will have a botched job in a hurry remember the vanier is 3/32 or some times less thick some may be thicker shop around on the web you may find some that is a bit thicker for exterior service. You may need the long grain 10'' ply if you have a long cabin it is worth it when done the trim is a job you may need some wood shop to cut or rouder the pieces for you measure it several times before you cut it shrinks and grows with out warning and you cant strech that $50.00 piece of teak even a quarter inch thats just crap. And they want the same price for a new piece after a couple of hundred dollars they should feel sorry for you right Buying the wood with long grain and clean for the cabin can be a chalenge but some sites have full descriptions of the wood they sell even photos.
Teak or no teak... Keyne Boat Review and Purchase Forum 20 08-10-2006 07:08 PM
Teak deck removal or replace Myblueheaven General Discussion (sailing related) 1 10-30-2004 12:55 PM
Replacing a teak deck docket Gear & Maintenance 0 03-28-2002 06:29 PM
Teak deck Q ekhar Gear & Maintenance 8 03-10-2002 06:48 PM
Diesel Stain in Teak Veneer vikinglady herSailNet 1 07-22-2001 10:35 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
