moving chain plates - Page 2 - SailNet Community
View Poll Results: move chain plates to sheer
yes and why 3 33.33%
no and why 6 66.67%
Voters: 9. You may not vote on this poll
 6Likes
post #11 of 12 Old 12-07-2013
Senior Moment Member
SloopJonB's Avatar
Re: moving chain plates
Moving chains OUT to the hull will reduce rig stress so I doubt an N/A would need to be involved.
Moving them IN is an entirely different matter - rig compression can go up significantly, depending on how narrow you make the base.
Having said that, I can't see any reason for moving them out - they still have to be sealed and maintained, the rigs performance will be degraded, it will cost $$ and gain no benefit that I can see.
Make sure the existing ones are in good shape and seal them properly.
'Nuff said.
Faster and christian.hess like this.
SloopJonB is offline
post #12 of 12 Old 12-07-2013
'Nuff said.
This is true, assuming there is somewhere outboard that is strong enough in the vertical to handle the loads of the chainplates. Sure you could just bolt them to the side of the boat, but how do you know if they are strong enough in tension? Sure there are some boats that it would be fine on, on others you could rip the side of the boat off.
Your boat, your choice. But before moving major structural elements I want someone to run the numbers.
mitiempo and christian.hess like this.
Greg
Stumble is offline
Chain Plates eherlihy O'Day 15 01-24-2017 10:59 AM
Chain plates Ruthlessrider Grampian 12 08-16-2013 01:11 AM
chain plates Bob142 General Discussion (sailing related) 8 06-14-2012 01:33 AM
chain plates amblin909 Announcements and Suggestions Box 2 12-10-2009 06:09 PM
Chain plates are out, now what? jrd22 Gear & Maintenance 11 12-30-2007 11:06 AM
