Old 04-08-2001
d14carter is on a distinguished road
Refurbishing Cabin Sole
We have a Morgan 366 with a worn-out cabin sole. We would like to refurbish it, without sanding since the teak layer is very thin. Any suggestions on chemically removing the top coat, as well as the products to use for recovering the sole. Thanks
Old 04-09-2001
express is on a distinguished road
what do you mean by worn out? Is the teak/holley worn and you to replace or do they just need refinishing.
Old 04-10-2001
The sole just needs cleaning then refinishing. I am looking for what products to use and how to go about it.
Old 07-19-2001
Cahill is on a distinguished road
Ahhh, grunt work. The cabin sole in Xanadu is oak with teak accent. I recently (last fall) stripped it with jabsco paint remover, sanded with 120 grit wet/dry, then applied Deks Olje teak oil (matte finish). Four of us live aboard, so the finish had to withstand a considerable amount of traffic. I''m quite pleased with the results, though I still get flashbacks from the jabsco vapors!
Advice refinishing teak and holly sole mcagney Gear & Maintenance 11 09-24-2009 07:03 AM
ISLANDER 29 CABIN SOLE mauricefrompolo Gear & Maintenance 2 03-02-2009 10:57 PM
Cabin Step Mast JNBDeVore Gear & Maintenance 6 10-03-2007 12:35 PM
Cruising Advice Needed!!! 2 or 3 cabin for 3 single guys? robbieturner Cruising & Liveaboard Forum 5 10-17-2001 05:26 AM
vinyl cabin sole creek Gear & Maintenance 0 03-20-2001 05:47 AM
