Sailboat performance change - Page 2 - SailNet Community
post #11 of 14 Old 12-09-2013
no longer reading SailNet
Alex W's Avatar
Re: Sailboat performance change
Originally Posted by Delta-T View Post
If understand it correctly, the head sail gives you power and the main gives you heal (and weather helm adjustment).
This is not universally true. It is true of many 70s boats that were designed to IOR handicapping rules.
Saying that the main gives you heeling and weather helm adjustment is also not accurate. The main still gives you power, it is just that most of these boats had 2/3rds of their sail area on the head sail. You can prove this by dropping your main sail and seeing that you slow down (unless you are in heavy air) and won't be able to point as high.
Alex W is offline
post #12 of 14 Old 12-09-2013
Delta-T's Avatar
I sail 80% of the time with only the 150% head sail. Boat is well balanced this way. And yes, head sail gives me better pointing. Sailing with main only is not an option for my boat, boat goes nowhere without head sail. I always wondered why, assuming the placement of the mast is too far back. But now we are going OT. And, as you point out performance is different for each size and design of boat.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #13 of 14 Old 12-10-2013
Barquito
Barquito's Avatar
My first thought with regards to performance would be that because the center of effort of the sail is raised, then, given that there is less sail area, at the wind speed that would produce the same amount of power as the bigger/lower sail, the heeling force would be greater... but probably not enough to worry about.
With regards to the dodger design: I would lower it, and look over the top.
Bristol 27
Cirque
For Sale
Valiant 32
Barquito is online now
post #14 of 14 Old 12-10-2013
Dodgers should be fold-downable. Maybe larger plastic windows would help. Walk the docks to see one that you like and then ask the maker for ideas . Smaller main affects balance, probably not a big item on the Cal as they use a variety of jibs.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
If you want to change the sailboat by a motorboat.... PCP General Discussion (sailing related) 6 05-15-2013 02:54 PM
Sailboat building in the blood - High Performance Composites NewsReader News Feeds 0 07-01-2012 11:50 AM
Sailboat Performance Improved With The World?s Strongest Fiber - E-Composites NewsReader News Feeds 0 04-16-2007 06:15 PM
recommend small (22-28'') performance sailboat winslow59 Boat Review and Purchase Forum 14 12-14-2003 10:52 PM
Propeller performance change - feathering paulmcquillan Gear & Maintenance 2 10-20-2003 08:48 PM
