Building an emergency rudder- 2 questions; - Page 2 - SailNet Community
post #11 of 16 Old 12-09-2013
mitiempo's Avatar
Re: Building an emergency rudder- 2 questions;
I use margerine containers.
Brian
mitiempo is offline
post #12 of 16 Old 12-09-2013
aeventyr60's Avatar
No, no, the best has to be tuna fish cans...
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #13 of 16 Old 12-09-2013
mitiempo's Avatar
But they don't survive the flexing to get the hardened epoxy out.
Brian
mitiempo is offline
post #14 of 16 Old 12-09-2013
aeventyr60's Avatar
If you poke a hole in the bottom you can string em together and make a home series drogue!
post #15 of 16 Old 12-09-2013 Thread Starter
Irunbird's Avatar
Thanks, guys! Tons of great ideas here. I talked with a friend of mine (fiberglass, paint guy, who does a lot of this work for a living), and discovered that I probably should have mixed in some high density filler (404) with the epoxy for my layers in between. I had planned on creating a groove and burying a length of stainless angle along the long axis, but he seemed to think that wasn't absolutely necessary as long as I thickened the epoxy for the outer layers of cloth that I use to glass the exterior of the rudder. I may still do that just to be absolutely sure. I could add one more layer with the 404 mixed in just to be sure...
Irunbird is offline
post #16 of 16 Old 12-09-2013
One of None
deniseO30's Avatar
You may want to check the bond between the layers of foam core, it may not have bonded because epoxy will "soak in" when not thickened. Best to find out now! good luck!
My last project!
deniseO30 is offline
Let's build an Emergency Rudder! (or not) deniseO30 Gear & Maintenance 21 03-04-2013 05:26 PM
New kind of emergency rudder Bene505 Gear & Maintenance 19 12-07-2010 11:59 AM
M-RUD emergency rudder rdw Gear & Maintenance 0 11-01-2010 09:03 PM
Emergency Rudder Post Fiberglass Cracking SVArgo Pacific Seacraft 0 08-09-2010 09:24 AM
Emergency rudder ideas ? jbrockpiano Gear & Maintenance 11 12-04-2007 07:07 PM
