gear and maintenancee - SailNet Community
post #1 of 4 Old 01-20-2005 Thread Starter
I would like to repair or refurbish my hydraulic steering on a 1975 Morgan IO 41.
Looking for recommendations on repalcement or place to refurbish existing system.
Thanks
DARTHZ1 is offline
post #2 of 4 Old 01-20-2005
Try this website to start. I have this system on my 47 foot ketch. seastarsteering.com
Kyle
Trami is offline
post #3 of 4 Old 01-25-2005 Thread Starter
Thakns for the info. I filled out the data sheet and sent it to the company for their recommendation. Does your system have resovoir filled with fluid that is pumped up with an external air pump?
DARTHZ1 is offline
post #4 of 4 Old 01-25-2005
DARTHZ1,
My reservoir is up at the wheel. The pump is within the reservoir. The fluid is pumped by a series of revolving pistons when the wheel is turned. The pistons pump the fluid down to the cylinders. I''m no engineer so that is the best I can describe it. I dismantled it myself to replace seals without any trouble. Pretty simple design actually. My pump is made by Capilano, which I believe is on the Seastar website. Good luck with your search.
Kyle
Trami is offline
