Sewing machine corner - Page 4 - SailNet Community
 24Likes
post #31 of 41 Old 12-23-2013
Re: Sewing machine corner
Has anyone used any of the other Singer machines with success? Prices range from $99 - 499 on the net.
I just broke my old mechanical Singer and need a replacement for canvas, cushions and general repairs. I am not going to do any sail making. That I am going to leave to the experts.
Can you recommend any models?
Newport 30 Mark III 1986
Uncle Joey says, if the screw won't go all the way in, you are not using a big enough hammer!
heelangle is offline
post #32 of 41 Old 12-23-2013
no longer reading SailNet
Alex W's Avatar
What broke on your mechanical Singer? Might it be cheaper/easier to fix than to replace?
I have a lower end Pfaff Hobby that works nicely on cushions and lighter weight materials. It is easier to use (threading, bobbin winding, built in thread snipper all make it faster for me to use) so I use it until I need the power of the Sailrite machine. I leave my Sailrite machine adjusted for higher tension and pressure foot tension and the Pfaff adjusted for lighter fabrics.
Alex W is offline
post #33 of 41 Old 12-23-2013 Thread Starter
If you wanted a singer here are a couple that I saw in your area on the cheap.
The 301 and 401 machines are decent machines that are a little step up from the home machine. They can handle the thickness of the material pretty well and as are still somewhat compact. There are some other machines out there that would be good though best thing to do is see what you can find and then ask questions about specific models. Here are some CL listings.
Heavy Duty Singer 401A sewing machine with Carrying Case
Singer CG-550C commercial sewing machine
gedaggett is offline
post #34 of 41 Old 12-23-2013
Owned by Velcro
Ferretchaser's Avatar
Originally Posted by hurricanehole View Post
Hi-thanks for doing this. I have a red sailrite machine and would like to know if I could take it to my moored boat and sew with it running off a small red honda generator, EU200i. If so that would push me over the edge in buying a small gen.
At the moment, our EU200i is running the full size fridge, Christmas decoration lights, two laptops, keeps the boats batteries charged and running the Sail Rite sewing machine. All on the economy setting and it is not even picking up the revs. Been doing that for 3 weeks now day in day out.
ATB
Michael
downeast450 likes this.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #35 of 41 Old 12-23-2013
If you have room and the time to wait, sometimes a Singer 111W155 becomes available on craigslist. The 111W155 is an industrial compound walking-foot machine. My earlier post on compound walking-foot machines on this thread might be helpful.
The disadvantages include: used, likely heavily used; $500 might be about as good as you could do (I got one with a clutch motor for $325); probably not be equipped with a servo motor; no reverse.
Also, seeming lightly used Sailrite LS machines can sometimes be found for about $500 on craigslist.
Actually, trading off lack of reverse for compound-feed can be a good trade off. The most common use of reverse is back-tack to lock the stitch. Here's what old-time professional sewers did before reverse. When fabric management is not an issue, simply bury the needle, turn the fabric 180 degrees and sew over the seam to lock the stitch. Otherwise, with the needle up, raise the foot a bit, pull the fabric toward you about an inch, drop the foot and sew over the stitch to lock the stitch. Raising the foot slightly does not open the tension discs, and enough tension is retained on the needle thread that the thread does not need to be held.
Having said that, reverse is useful in other situations to help mitigate fabric management, such as sewing around a patch, especially in the middle of a large piece. Needing to turn the fabric a total of 360 degrees is a real hassle trying to get lots material under the arm. Instead, sew one side of the patch, bury the needle, turn the fabric 90 degrees counter-clockwise and sew the next side, bury the needle, turn the fabric 90 degrees clockwise and sew the third side in reverse, bury the needle, turn the material 90 degrees counter-clockwise and sew the final side.
In your search, you might also consider a Juki 562 or 563 (the 563 has a larger bobbin). The design is similar to the 111W and the quality seems just as good.
TejasSailer is offline
post #36 of 41 Old 12-28-2013
Missingyou's Avatar
I just dragged an old Juki LU 563 back from Hamilton Ontario, it's built like a tank. $500, which included a new servo motor. It went through two thick pieces of leather like butter. I plan to make a winter cover with it, among other things. It's a compound feed walking foot machine, but unfortunately not very portable. Lifting it and the table took two of us.
Missingyou is offline
post #37 of 41 Old 12-28-2013
A Juki 563 in good condition with a servo motor for $500 is a real deal. Here's a refurbished one for $1265.
Refurbished Juki LU-563 on Stand
Send me a PM if you'd like a good copy of the user manual and/or parts manual in pdf form.
Also, you might be interested in chapter 4, Sewing Machine Repair, of the following link that states.
"Your shop may have the Consew Model 225, the Juki LU-562, or the Singer Model 111 W 155 sewing machine. These three sewing machines are essentially identical, and all specifications and instructions are the same for all three sewing machines. For simplicity we will use the Singer 111 W 155 as a model for all three sewing machines."
The juki 562 and 563 are essentially the same except that the 563 has a large bobbin. The manual fails to mention that the Juki has reverse.
http://navybmr.com/study%20material2...RA%2014217.pdf
post #38 of 41 Old 03-13-2014
Hi I am new to this forum .
I bought a Juki 563 today and can not find a proper copy online
I tried to PM you but because I am a new member it is impossible to do.
Can you help me with a copy ?
Peter
amphicar is offline
post #39 of 41 Old 03-13-2014
Missingyou's Avatar
I have the manual for the 563 and 563N as well. Can send if you like.
post #40 of 41 Old 03-14-2014
Brian,
I have send you an email , please send it to me
thanks Peter
amphicar is offline
Sewing machine? canucksailorguy General Discussion (sailing related) 52 09-24-2012 11:11 AM
Looking for sewing machine ambianceack Boat Review and Purchase Forum 2 05-30-2012 10:40 AM
Sewing machine or ???? poopdeckpappy Gear & Maintenance 8 04-06-2011 05:22 PM
Sewing Machine Dmarina General Discussion (sailing related) 1 07-21-2008 04:09 PM
sewing machine svdragonseeker Living Aboard 5 04-22-2002 01:53 PM
