EMS gauge removal - SailNet Community
post #1 of 5 Old 12-12-2013 Thread Starter
EMS gauge removal
I have old ~4" EMS bulkhead mounted wind speed and depth gauges that I would like to remove. Anyone know how? Does the exterior weather ring unscrew? If so, is there a tool for that? I don't see any conventional screws anywhere.
Also, any suggestions for plugging the resulting holes? I would like to install a small chart plotter bracket over one of the openings.
Thanks.
SailNoFo is offline
post #2 of 5 Old 12-14-2013
Dave_E's Avatar
Re: EMS gauge removal
Welcome to the forum!
It's like this: if you work on your boat... sometimes you look at something and just have to figure it out. Unless someone here has that exact item in the exact same kind of mounted position, your not going to get too many answers. So, have a look on the back side. Do an internet search for the instruments, might get lucky. Most likely any mounting is back there and the gauge will pull out from the opposit side. Plugging holes can be a pain and end up "not-so-pretty". Why not leave the dead gauge in the hole?
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #3 of 5 Old 12-14-2013
Dave e's right, Just will take a little prying and fiddling to figure it out. As far as plugging the holes; you can make some teak plugs that have a lip on the outside. They will protrude from your bulkhead though.
benesailor is offline
post #4 of 5 Old 12-14-2013
rugosa's Avatar
The wiring connections are at the back of the instrument so look for access there. There is usually some sort of clamping/securing devise on the back, once you expose it should be a screw driver and not much else. BUT, beware of the siliconed in place face, so you might need to get behind the bulkhead flange on the instrument with a putty knife or similar.
Teak makes a good cover if you are ok with maintaining the teak, and you should be able to screw from behind to secure. With the Hunter 23 being mostly molded FG instead of a lot of exterior wood 1/4" acrylic might also work and eliminate the maintenance. Filling the holes works, but expect it to weather different than original.
rugosa is offline
post #5 of 5 Old 12-14-2013
jimrafford's Avatar
Most likely they are secured by a ring w/ set screws from the back side.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
Effective remedies for the no-see-ems sailhog General Discussion (sailing related) 32 02-06-2015 04:44 PM
Older EMS gauges ckgreenman Gear & Maintenance 8 10-06-2009 11:09 PM
Gauge Problems Mark Matthews Gear and Maintenance Articles 0 09-24-2002 08:00 PM
Looking for info on EMS instruments colehankins Gear & Maintenance 2 04-14-2002 08:55 PM
