bilge water - SailNet Community
post #1 of 16 Old 12-13-2013 Thread Starter
captain jack's Avatar
bilge water
quick question. i am installing an automatic bilge pump. the manual bilge pump is in a side compartment, on the starboard bench. it has a hose that runs to it, from the lowest point, just above the keel bolts. this is, of course, where i am putting the pump. i was going to route the hose, from the pump, where the manual hose is routed. that would bring it out into that storage compartment.
there is a small well, that extends below the level of the cockpit sole, where any cockpit water is dumped and runs out through the hole in the transom. is there any reason i can't just put the through hull in the side of the bench ( higher than sole level ), dumping any water into this well, so it runs out of the hole that is already in the transom.
i think it's a great solution because it keeps me from adding another through hull and i won't have to worry about water backing into the hose. i figure, if i have that much water in the cockpit, to where it can backflow into the pump, the backflow is going to be the least of my worries.
thanks
captain jack is offline
post #2 of 16 Old 12-13-2013
paulk's Avatar
Re: bilge water
Bilge water may not be as clean-smelling as the rain and spray that drains from the cockpit. Our electric bilge pump pumps into the anchor locker, and drains from there, but it is up forward by the shrouds so we don't care so much.
paulk is offline
post #3 of 16 Old 12-13-2013
MarkofSeaLife's Avatar
Dock
Re: bilge water
Anything that saves another thru hull could be a good idea.
Can you test it for a while and if it doesnt work then do the thru hull?
If its stinky a bucket of water with flush the cockpit.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #4 of 16 Old 12-13-2013
nodders's Avatar
Re: bilge water
That is a really interesting idea! I will be re-thinking my installation plans!
I am not really from Toronto
nodders is offline
post #5 of 16 Old 12-13-2013 Thread Starter
Re: bilge water
sure. if it doesn't work out, i can always add a through hull. i am thinking like you: one less through hull can't be bad.
post #6 of 16 Old 12-13-2013 Thread Starter
Re: bilge water
that's pretty cool. it seemed logical, to me.
post #7 of 16 Old 12-13-2013
Re: bilge water
As long as the sump is low enough that you don't end up puddling in the cockpit it should be fine.. but you could also direct it out the transom at a similar height and avoid water/smell in the cockpit. The added bonus with that would be an audible indication that your pump is running when you hear the splashing aft.
Faster is offline
post #8 of 16 Old 12-13-2013 Thread Starter
Re: bilge water
thayt was my other option, actually. the sump is pretty deep and sizeable. not sure if i have a pic i can post depicting it. Michael might have one, in the photos he posted in his profile, for me.
i like this option, though, because it avoids another through hull...less risk of back flow. i would add a check valve but the pump instructions expressly say not to do that.
post #9 of 16 Old 12-16-2013 Thread Starter
Re: bilge water
got it done! it works great and it looks good. i will post pics after dinner.when i bought the boat, it had no hatch or hatchboard. so, it had been rained in. they had maintained it with a pump, however. it still had about an inch of water in the bilge. it hasn't taken on any more, since i closed it in. so, as soon as i flipped the switch, it pumped out the water. it worked perfectly. poured into the well and out of the boat. no fuss. no problems. and no back up. tgat pump made short work of that little bit of water. i didn't even have time to snap a picture until it was just a trickle coming out.
The only rules that really matter are these: what a man can do and what a man can't do.---Captain Jack Sparrow
1971 Cal 27
post #10 of 16 Old 12-16-2013
azguy's Avatar
Re: bilge water
Great !
How are you running the pump, from shore power or a battery..??
1988 C22 Owner
azguy is offline
Water in the bilge Dave_E Gear & Maintenance 17 09-09-2013 01:30 PM
Water in the bilge inthesprings General Discussion (sailing related) 25 09-24-2009 02:44 PM
Bilge water BayDancer Catalina 1 07-08-2006 10:31 AM
Where does bilge water come from? chris1514 Gear & Maintenance 8 07-27-2003 07:51 AM
Water in the Bilge Dan Dickison Gear and Maintenance Articles 0 03-12-2001 07:00 PM
