Engine oil stains on deck gelgoat - Page 2 - SailNet Community
 2Likes
post #11 of 24 Old 12-14-2013
72 C&C Corvette
CorvetteGuy's Avatar
Re: Engine oil stains on deck gelgoat
Ive used a 1500 grit wet sandpaper to remove stains, little water a little pressure,,but dont go to far
CorvetteGuy is offline
post #12 of 24 Old 12-14-2013
Soft-scrub with bleach; works every time.
benesailor is offline
post #13 of 24 Old 12-14-2013
Sailor
Gladrags1's Avatar
After you try all methods to remove the oil and have lightened the stain, try this: Let the soft scrub sit on the spot for a while to let the bleach work. Maybe soak a rag in bleach and let it sit on the spot.
Good luck!
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #14 of 24 Old 12-14-2013
Chastened
Ajax_MD's Avatar
Also try oxalic acid. Bar keepers friend has it as an ingredient.
Sent from my DROID RAZR using Tapatalk
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #15 of 24 Old 12-14-2013
Lots of good advice here. It seems that there are are a number of approaches here - start at the top (least damaging) and work down!:
1) Absorbent materials (cloths, powders, baking soda) - Warmth will reduce viscocity and make the process more effective
2) Detergents - which help encapsulate the oil molecules. making it water soluble (e,g, dawn)
3) Bleaches - which lighten the color. This should work great if the oil is dirty (e,g, carbon or other residue).
4) Abrasives - which remove a thin layer of gelcoat
The only thing I have not seen is reference to a solvent. Try acetone.
Good luck!
paul323 is offline
post #16 of 24 Old 12-14-2013
deltaten's Avatar
Send a message via Yahoo to deltaten
.....and then ya havva smooth,clean, whiter spot!!!!
Clean as best ya can and live with it
But what gives with the spider poop????? worse than oil.
S/V Chrysalis
'80 Watkins 27
North East, MD
deltaten is offline
post #17 of 24 Old 12-14-2013
You have sinned! Mentioned spider poop! AAGGHHH! Hate spider & bird poop!
I used to think that if you kept your boat properly waxed that you would not suffer from these maladies. Now i know better. I am overrun with spiders and barn swallows. I can deal with spiders to some degree. I've had to use "Home Defense" as a perimeter on the boat to keep most out as my daughter blows up like a balloon when bitten.
The barn swallows, well, until they let me use the shot gun i'll have to deal with cleaning daily. I have about/roughly 30 birds that live on my boat all day. This is how i know so much about soft-scrub with bleach as i go through a bottle a week. It's the only way i can make the boat sanitary to sit on. Hopefully the marina will address the issue before they get back in the spring.
post #18 of 24 Old 12-14-2013
Delta-T's Avatar
I found the birds nesting in my neighbors open ended boom.
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #19 of 24 Old 12-14-2013
You must be my neighbor! The plug fell out and my neighbor informed me of the nest.
I have 6 nests under my dock finger alone. It's a hard dock on the land side so there is about 50 nests. If you have ever dealt with barn swallows before you can know how frustrating they can be.
Don't get me wrong; i love them. They are a gorgeous bird. It's just extremely frustrating cleaning mountains of poop off the boat every week (3 hrs). My boats my baby (100k baby, retirement home) and i agonize every week using soft-scrub on her. Most of my neighbors are large powerboats so they don't get it quite as bad. Still bad though.
Hopefully i have convinced the marina to put up netting before there return in the spring.
The other sailors come over to look and laugh at my dilemma. Plus side.... she is really clean every week for about a day or so. No mold, spider poop, nothing
Delta-T likes this.
post #20 of 24 Old 12-16-2013
Liquorice's Avatar
Tilex with Bleach - $6 a bottle.
Scrub with a deck brush and flush with cold water.
Don't over think this!
Sam :-)
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Liquorice is offline
Tags
deck , gelocoat , oil
Any tips on cleaning diesel smoke stains off deck? SoulVoyage Gear & Maintenance 6 06-23-2012 04:56 PM
Teak oil stains of fiberglass weinie Gear & Maintenance 4 07-18-2011 09:01 PM
darn deck stains QuickMick Gear & Maintenance 2 11-11-2009 05:14 PM
deck stains/green spots/and a little rust QuickMick Gear & Maintenance 6 11-05-2009 11:44 AM
Teak Oil stained the deck miggidy Gear & Maintenance 7 09-09-2009 10:27 PM
