Engine oil stains on deck gelgoat - Page 3 - SailNet Community
 2Likes
post #21 of 24 Old 12-16-2013
chucklesR's Avatar
Re: Engine oil stains on deck gelgoat
I've used FSR on oil stains, works reasonably well. Give it a good soak time.
Gel is porous, hence the stain. No matter what you use it must be allowed the time to penetrate.
chucklesR is offline
post #22 of 24 Old 12-17-2013 Thread Starter
thanks for the advice!! I will try to remove the stains next spring, when the snow that is covering the deck will melt
gloreg is offline
post #23 of 24 Old 12-17-2013
Do not wait until spring. The longer you wait, the further in the oil migrates, and the harder it will be to get it out by any means.
hellosailor is offline
post #24 of 24 Old 04-15-2014 Thread Starter
So I tried many thing and I came up with almost perfect results (you can't tell where were the spot unless I tell you). First I used dish was soap, then on off and the FSR. But only when I used 3M rubbing compound the oil stains disappeared without damaging the gelcoat. I do not know if what worked was the combination of the products or just the rubbing compound, in any case it worked and I am happy about it. Thanks for your valuable advices.
Delta-T likes this.
gloreg is offline
Tags
deck , gelocoat , oil
Any tips on cleaning diesel smoke stains off deck? SoulVoyage Gear & Maintenance 6 06-23-2012 04:56 PM
Teak oil stains of fiberglass weinie Gear & Maintenance 4 07-18-2011 09:01 PM
darn deck stains QuickMick Gear & Maintenance 2 11-11-2009 05:14 PM
deck stains/green spots/and a little rust QuickMick Gear & Maintenance 6 11-05-2009 11:44 AM
Teak Oil stained the deck miggidy Gear & Maintenance 7 09-09-2009 10:27 PM
