High capacity alternators - Page 2 - SailNet Community
post #11 of 12 Old 03-28-2005
Jon - I am re-outfitting - new diesel, and all new electrics, and have a few questions. What horsepower diesel are you driving that alternator with? Are the dual belts v-belts, or multi groove? And how is the alternator mounted - is there an additional crankshaft pully off the front of the engine, with the accompanying sideload, or did you install a stub shaft to drive a separate independent set of sheaves? And how many hours of use to you have on the system so far? Thanks, Jim D.
jimdsr is offline
post #12 of 12 Old 03-29-2005
I know youve done your due diligence, but Id like to suggest just a little more reading.
Follows some articles, offering a fresh point of view:
Understanding a model for battery charge acceptance:
http://cruisersforum.com/showthread.php?s=&threadid=1442
How "fast" you can reliably charge your battery.
http://cruisersforum.com/showthread.php?s=&threadid=1432
HOW TO SIZE AND USE YOUR BATTERY BANK
http://www.glacierbay.com/1batcrg.asp
HTH,
Gord May
GordMay is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
High Output Alternators Stormer_2003 Gear & Maintenance 3 10-13-2004 12:16 PM
High Tech on the High Seas Epiphany General Discussion (sailing related) 3 01-25-2004 02:32 PM
Avon high pressure floor mikemosabe Gear & Maintenance 5 08-17-2002 03:44 AM
House battery capacity wwilson Gear & Maintenance 7 03-07-2001 08:06 PM
