SILICONE to mount in-hull transducer? - Page 4 - SailNet Community
 11Likes
post #31 of 36 Old 12-20-2013
mitiempo's Avatar
Re: SILICONE to mount in-hull transducer?
Originally Posted by algee View Post
There is a product called Duct Seal Compound. It costs less than $5 at the big box hardware stores. I going to try it. Have any of you tried it?
Looks a bit like butyl. The more solids in the material used the less effective the depth sounder. Use silicone or epoxy.
Brian
mitiempo is offline
post #32 of 36 Old 12-20-2013
Argyle38's Avatar
For those that have installed the P79, can I ask how you rate the performance? I have a Raymarine DSM300 that I bought last year but haven't installed it yet. My choices for transducer is one of the through hull designs, the P79 or the much more expensive M260.
I've always leaned toward an in-hull transducer since I have a solid glass hull. I have plenty of room for the larger M260, but at 5x the price over the P79 it seems like it might not be worth it for an extra 400W of power.
So, do you like your P79's or do you wish you had more power?
Have you been able to compare to through-hull type transducers?
Also, what type of module and display to have it attached to?
-Argyle
S/V Argyle
Downeaster 38 #40
Argyle38 is offline
post #33 of 36 Old 12-20-2013
Asleep at the wheel
jimgo's Avatar
Is there usually air trapped in the silicone in a tube?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #34 of 36 Old 12-20-2013
mitiempo's Avatar
It's easy to get bubbles in silicone. That is one reason I use epoxy.
jimgo likes this.
Brian
mitiempo is offline
post #35 of 36 Old 12-22-2013
christian.hess's Avatar
Ill be doing this soon on a cheap garmin fishfinder....mounted in hull
Ill be going the mineral oil in a pvc tube cap way as it is completely "removable" jajaja not that it needs to be...learned this trick from you guys on here.
I hate clear silicone and anything remotely related to it like 5200 etc...much rather use manual methods
Ill post an update next year! jaja
cheers
christian.hess is offline
post #36 of 36 Old 12-22-2013
never understood why people want more power out of their depthfinders..what you need is the perfect spot to mount it perfectly upright so it shoots a clear uncorrupted line down to the bottom...
more power will only give your more ability to see larger depths...not what you need a depthsounder for
or is there more to it? my studies have shown me to look more at proper installment over "power"
No obvious way to mount wind transducer aaronwindward Electronics 5 08-13-2012 06:03 AM
Which In-hull transducer? 71Irwin32 Gear & Maintenance 2 02-22-2012 01:31 PM
Best in hull transducer Waltthesalt Electronics 3 03-25-2011 09:20 PM
Through-hull transducer? flyingwelshman Gear & Maintenance 5 04-22-2008 11:27 AM
Thru Hull Transducer pixurman Gear & Maintenance 2 05-21-2002 07:04 PM
