Corroded aluminum port light- paint before using Buytl? - SailNet Community
 1Likes
  • 1 Post By baboon
post #1 of 3 Old 12-18-2013 Thread Starter
Salt water has corroded my aluminum port lights where they were bedded inside the hull. I have wire brushed and sanded off the corrosion. Should I treat with Alumaprep and spray with Zinc Chromate befoe bedding with Buytl?
Another words, will Butyl bond to Zinc Chromate or aluminum that has been treated with Alumaprep?
Thanks for your help!
Larry
justonemoreproject is offline
post #2 of 3 Old 12-19-2013
Re: Corroded aluminum port light- paint before using Buytl?
Butyl does not really "bond", but rather forms a sticky gasket. I have used it on glecoat, plastic, aluminum, steel and wood with no problems. It should work with painted surfaces too, but the failure point becomes the paint to the metal. With my ports I just cleaned the aluminum with wire brush and green scotch pads and after several years have had no problems or leaks. It creates such a good waterproof seal that I have not worried about corrosion on the inner surface.
christian.hess likes this.
baboon is offline
post #3 of 3 Old 12-20-2013
We use butyl on mill aluminum at work (skylight mfg) with no problems after years of service.
DonScribner is offline
The Following User Says Thank You to DonScribner For This Useful Post:
justonemoreproject (12-21-2013)
Paint/Coating for leaky aluminum dinghy? sealover Gear & Maintenance 10 02-20-2012 03:52 AM
Engine: To paint or not to paint aluminum and bronze parts dennisvetter Gear & Maintenance 4 03-19-2011 10:06 AM
Aluminum Tank Inspection Port cruiserdave Gear & Maintenance 2 02-26-2009 04:54 AM
Aluminum: To paint or not to paint mentalfee Gear & Maintenance 4 04-02-2008 09:03 PM
healing corroded/oxidized aluminum? Nelsie Gear & Maintenance 3 08-27-2007 01:30 AM
