Old 02-14-2005
amunk is on a distinguished road
plywood-epoxy construction
I am considering a custom 35'' sailboat constructed from plywood-epoxy. I would appreciate some insight about this type of construction. I plan to live aboard and sail from the great lakes south to the Florida keys and beyond. The boat has a shallow draft and the living space is adequate for my needs. I really want to know more about the construction and what to look for.
Thank you
  #2
Old 02-14-2005
sailnaway is on a distinguished road
This would be a good place to start I think you will find allot of stuff on boats. Dont let the Kayak thing throw you off.
http://www.seekayak.com/Reference_Resources/Kayak_Building/Materials_and_Tools/
  #3
Old 02-15-2005
Jeff_H's Avatar
Administrator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
I think that you need to provide more detail because there are a number of contruction approaches that could loosely be called "plywood-epoxy" and they vary quite widely in their quality, and durability. Epoxy saturated cold molded plywood, in which individual veneers are laid up to create a hull that is in effect a single sheet of plywood can produce one of the strongest (for its weight), low maintenance, and most durable boat building techniques that there is. At the other extreme is a boat built from sheet plywood that is sealed with unreinforced epoxy resin, which is a pretty inexpensive way to build a boat but which is not all that strong or durable. There is an extremely wide range of variations in between.
  #4
Old 02-15-2005
jmcornelis is on a distinguished road
You might find it worthwhile as well looking at or even joining the Wooden Boat Forum: http://woodenboat-ubb.com/cgi-bin/UBB/ultimatebb.cgi.
Or try: http://www.messing-about.com/forum/viewforum.php?f=1&sid=6dd7286a3b5106dfcf0ab5569645 7e4e
Jake
  #5
Old 02-23-2005
FalconEddie is on a distinguished road
I highly recommend you follow the suggestions of the previous posters and research every web site and wooden boat organization you can.
I was originally going to go exactly that route: laminated and epoxied plywood over traditionally fashioned and fastened oak framework. I was willing to accept hard chines to maintain the great strength of the plywood and ease construction. Then I discovered something very important that changed my mind.
First, when you accurately list and outline all the materials and equipment you need for a 35 foot boat, you will find that the cost of the hull and deck amount to about 1/3 of the total price. Secondly, going to the traditional ''cost savings'' methods of plywood or ferrocement construction, you only save about 1/3 the cost of the hull and deck. So, logically, the truth is, after all is said and done, you may save only 1/9 the real cost of the boat and end up with three things: a boat no-one else will buy, a boat that is very vulnerable to catastrophic failure, and a boat that performs poorly.
If it is still your wish to go that route, then I wish you all good fortune and happy sailing.
But . . . .
Let me suggest a possible alternative . . . .
I am down here in central Florida. The land of whup-ass hurricane damage, if you remember. Down here in boat storage yards everywhere, are MANY boats in the size range you''re looking for, and they are some forlorn-looking sad-sack little bunnies, just waiting for someone just like you to low-ball the owner and truck your near future dream away. While they look like the end to some, they are the beginning to others.
You may post attachments
You may edit your posts
Glassing hull GreenEarth General Discussion (sailing related) 18 06-19-2009 11:52 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Plywood replacement Gene4er Gear & Maintenance 0 10-29-2002 05:41 AM
Epoxy on Carvel planking crkelly Gear & Maintenance 2 03-10-2001 08:39 AM
Epoxy Barrier coat stevemorrell General Discussion (sailing related) 3 11-07-2000 02:13 AM
SEO by vBSEO 3.6.1
