Plastic or Aluminum for water tanks? - Page 2 - SailNet Community
 3Likes
post #11 of 16 Old 12-20-2013 Thread Starter
Re: Plastic or Aluminum for water tanks?
Thanks everyone. It sounds as if the consensus is against aluminum due to the pitting issues that can come from bleach sanitizing. Maybe I'll get pricing on steel vs plastic at this point. Sounds as if plastic may be more susceptible to mold growth, but then again you can bleach the heck out of it.
We use this water in general for non-potable use unless I'm boiling water for cooking pasta, etc. Does that change anything? I don't see how, but I could be missing something.
doug1957 is offline
post #12 of 16 Old 12-20-2013
I had a custom poly tank made with a 10" inspection port. If it were any bigger, I would be able to climb in.
Jeanneau 54DS
Minnewaska is offline
post #13 of 16 Old 12-20-2013
Sailing Junkie
ehmanta's Avatar
My 36 year old boat has 2 plastic water tanks with two inspection ports each, one forward, one aft. These tanks have never given me an issue nor have they ever leaked. I do shock them with a bleach concentrate in the spring, flush a few times and then add a touch of bleach with each tank fill. I do drink from the tanks but I also have it run through a charcoal filter under the galley sink.
Hope this helps.
Tom
Edit: I have replaced the hosing on the potable system though.
"Dragonfly"
Tartan 4100, #28
ehmanta is offline
post #14 of 16 Old 12-20-2013
Delta-T's Avatar
An one using an Ultraviolet Purifier (12V)? BioLogic Ultraviolet Water Purifier Standard Models
Add to the water pump a voltage sensing relay to operate the UV only when pump is running. http://atkinsonelectronics.com/manuf...s/VRDC-40A.pdf
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #15 of 16 Old 12-20-2013
I have 2, 70 gal built-in fiberglass water tanks on my boat with inspection ports. The nice part is that the tanks lids are glued and screwed on. Unfortunately my front tank has developed a leak.(Crack i believe)
The good part is that i can take the lid off with some piano wire (cutting the adhesive) and do repairs.
I don't know that FRG is the best, but, i feel that it utilizes the space well.
I'd go with plastic with any tanks if i had to replace tanks.
benesailor is offline
post #16 of 16 Old 12-20-2013
If you want GREAT, safe drinking water with no power usage. Use the Nature Pure QC 2. 800 gals per filter and for winterization you disconnect the filter and take it home.
Nature Pure QC2 Purifier - Basic Model - Water Purifiers and Water Micro Filters - General Ecology
Plastic holding tanks- Are they legit? stiffwind Gear & Maintenance 19 01-02-2012 12:16 PM
Plastic v aluminum ports ccriders Gear & Maintenance 2 12-10-2010 11:04 AM
water tanks leaching plastic taste granche1 Pacific Seacraft 36 10-14-2010 09:14 AM
Aluminum vs Stainless water tanks I33 Gear & Maintenance 13 06-13-2010 02:15 PM
Plastic water tanks sirromcd Gear & Maintenance 5 09-06-2008 11:36 AM
