Dangers cutting carpet out - Page 4 - SailNet Community
 15Likes
post #31 of 42 Old 12-24-2013 Thread Starter
floatingcow's Avatar
Location: San Francisco Bay Area (Petaluma @ the moment)
Re: Dangers cutting carpet out
OK, so now I am rethinking some of this. I have been researching insulation, foam, carcinogens, off gassing, flammability, etc…
What about cork up against the fiberglass hull, covered by mold/mildew resistant material such as the Formica? I found this link helpful:
Show me your sailboat's interior
Part of me wants to believe we’ll never have to worry about fire because we’re careful people AND there’s so much frikken Styrofoam and other carcinogens in our lives anyway that the exposure to it is going to happen anyway. I’ve seen that argument from people on here plenty.
Then there’s the other side, (I’ll fall back on Sailingdog’s thoughts), the train of thought that I’m really more drawn to. Why not try my best to expose myself, my wife and my new baby girl to the absolute least bad stuff possible. It’s a no brainer! Here’s the thing though; it’s hard to know what that is.
Just give me the answer somebody! Tell me what’s best for goodness sake! Oh, and please make it cheap, easy to work with and permanent but removable.
Looks like I’ll be taking back a sheet of rigid foam board insulation and ordering a roll of 100% cork instead.
JD
Come join our family as we introduce our little adventurer to a life of travel, backpacking, biking, sailing and some hard work aboard our 37ft sailboat, Gone Tomorrow!
floatingcow is offline
post #32 of 42 Old 12-24-2013
We used the blue closed-cell foam pads that campers use to sleep on under our batten ceilings.
christian.hess likes this.
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
floatingcow (12-24-2013)
post #33 of 42 Old 12-24-2013
christian.hess's Avatar
thats fire resistant? hmmmmmmmmmmmm I can find that stuff I think at pricemart
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #34 of 42 Old 12-24-2013
Not positive it's fire resistant .......but it's easy to find and inexpensive.
Faster is offline
post #35 of 42 Old 12-25-2013
Unless you look for thermal insulation maybe something like a vinyl wallpaper. I've seen some very heavy duty commercial glue on with a foam backing. Washable and flexible enough to conform to a bit of hull shape. Plain or pretty patterns too.(polyethylene foam like yogi pads don't glue on very well)
Capt Len is offline
post #36 of 42 Old 12-25-2013
well next week it is ....vynil and foam thats what I have bought with ash wood battens...
all I can do for now
wish me luck
christian
post #37 of 42 Old 12-26-2013
Minnesail's Avatar
Originally Posted by hellosailor View Post
If you're using a spray like 3M "Sprayment" that also comes in different grades, I think #77 is their permanent grade.
It wasn't on a boat, but a couple months ago I tried some 3M 77 to laminate EPS foam to plywood and a lot of it failed. It couldn't handle temperature variation and just sort of peeled away.
A couple weeks ago I used 3M 78 and it worked like a charm! I recommend it.
Again, this was EPS foam to plywood, not on a boat, your mileage may vary.
Catalina 22
on a starboard tack
Minnesail is offline
post #38 of 42 Old 12-26-2013
Minne-
You can always check with 3M's 800 number. But from their brochure
http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
it looks like the spray they recommend for use on wood is #90, not #77.
FWIW.
hellosailor is offline
post #39 of 42 Old 12-26-2013
Minnesail's Avatar
Minne-
FWIW.
Excellent resource, thank you!
From that brochure it recommends #78 for rigid foam (EPS) which is probably why that stuff is working for me.
It says #74 for flexible foam, which probably applies more to headliner boat use.
I know this has been said before, but buy a small amount and try it on some test pieces first is always the best advice.
Catalina 22
on a starboard tack
post #40 of 42 Old 12-27-2013
thanks for the tips guys...
Carpet in cockpit? lapworth Gear & Maintenance 13 03-25-2011 06:48 PM
Carpet in the cabin wintermute11 Gear & Maintenance 14 01-16-2009 11:01 AM
replacing carpet marinesniper Gear & Maintenance 5 02-15-2008 07:28 PM
Cabin Carpet rcibul Gear & Maintenance 4 08-15-2006 09:55 PM
Indoor Carpet MikeGebhart Living Aboard 1 11-09-2003 06:23 PM
