Bernzomatic Handy Torch, Solder, Rope Cutter Tool - SailNet Community
post #1 of 10 Old 12-25-2013 Thread Starter
Hi guys. Just want to share something I got yesterday from Home Depot. It is a Bernzomatic butane flame that has some attachments (only the solder and rope cutting attachments are really relevant). I have used it to cut some main sail tie-downs and screwed around with the included solder and it's not terrible.
I would think about it if you ever do electrical work away from AC or just don't want to mess with extension cords. For $15, not a bad thing to have around.
Bernzomatic Butane Micro Flame Torch and Accessory Kit-328630 at The Home Depot
PeterJYC is offline
post #2 of 10 Old 12-25-2013
Re: Bernzomatic Handy Torch, Solder, Rope Cutter Tool
I have had one of these for a few years. I also recommend it. Seems to hold the butane so it is ready to go when you need it. Great for soldering when you have no shore power, and even better than a soldeing gun for large pieces of metal.
Refills just like the old cigatette lighters. Remember those?
Newport 30 Mark III 1986
Uncle Joey says, if the screw won't go all the way in, you are not using a big enough hammer!
heelangle is offline
post #3 of 10 Old 12-26-2013
It is also great for putting heat to a screw or nut that is seized. You can very accurately place the heat.
ccriders is online now
post #4 of 10 Old 12-26-2013
Probably a bit irrational, but flame tools give me the creeps aboard. I don't even like the little torches for shrink wrap and prefer to use a heat gun. I had one of those mini torches that was defective and didn't shut off when you let go of the trigger. Imagine dropping it? I also have an electric rope cutter.
Jeanneau 54DS
Minnewaska is offline
post #5 of 10 Old 12-26-2013
If you figure out how to refill the little bernz o matic please let me know. The instructions are not clear, I've tried with the refill cylinder pointing up, down, sideways and it blows lots of propellent all over the place ( suggestion - don't refill near a flame, below decks or while smoking a cigar). I seem to get some butane into the torch and when I do it works great, very handy to have on board. Wish filling were easier though.
Dfok is online now
post #6 of 10 Old 12-27-2013
Usually you hold the gizmo upside down, with the filling port facing up. Then you hold the gas can upside down and insert it firmly into the filling port. This allows the liquid butane to be pushed down into the gizmo. There's usually some spray during the filling but shouldn't be a lot unless the gizmo or the gas can is defective. And when the gizmo is full, there's usually a sprayback of butane to let you know.
hellosailor is offline
post #7 of 10 Old 12-27-2013 Thread Starter
1:30 shows below:
PeterJYC is offline
The Following User Says Thank You to PeterJYC For This Useful Post:
Dfok (12-27-2013)
post #8 of 10 Old 12-27-2013
thanks, guess I've been overfilling it each time. It is a handy torch.
Dfok is online now
post #9 of 10 Old 12-27-2013
Unkle Toad's Avatar
I used to have a very similar handheld in my "whatever" crafting kit .. think Ill get a new one handy thing to have around.
We Have nothing to fear but Reefs and Pirates
Unkle Toad is offline
post #10 of 10 Old 12-28-2013
poopdeckpappy's Avatar
I have a Ronson Auto start tech torch, handy little booger, hell, you can light your pipe with it
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
Proper Crimping = STRONG! (crimp vs. solder) Maine Sail Gear & Maintenance 62 10-09-2012 04:27 AM
Rope cutter for saildrive Giulietta General Discussion (sailing related) 23 12-30-2008 01:06 PM
How To Solder CoaxTerminals 1970Columbia34 Gear & Maintenance 21 03-22-2007 04:01 AM
FYI - Freeware Tide Tool V2.2 is now in Tide Tool Beta 2.3 (Runs on NewsReader Mass Bay Sailors 0 03-03-2007 04:15 PM
Prop rope cutter Philip Littman Pacific Seacraft 0 11-14-2006 01:10 PM
