to cut or not to cut. that is the question. - Page 4 - SailNet Community
 7Likes
post #31 of 45 Old 12-27-2013 Thread Starter
captain jack's Avatar
Re: to cut or not to cut. that is the question.
Originally Posted by deniseO30 View Post
3 pages of discussion for a cleat and 2 bolts?? I could've built a boat by now! LOL
wow. you are good. i am outclassed.
there are a lot of people with good ideas. nothing wrong with that. hopefully, some other guy, with the same problem, will find this thread in the future.
The only rules that really matter are these: what a man can do and what a man can't do.---Captain Jack Sparrow
1971 Cal 27
captain jack is offline
post #32 of 45 Old 12-27-2013 Thread Starter
Originally Posted by Seaduction View Post
Put a new cleat somewhere that you can accomplish the task. Then remove the old one and plug the holes. Looks kinda tight where its at now anyway. Otherwise, a new coaming storage box would be a neat addition.
the cleat isn't the only issue or that might be a thought. i still need to replace that screw in the rail base, though.
1971 Cal 27
post #33 of 45 Old 12-27-2013
Tartan 27' owner
CalebD's Avatar
Is your boat a Catalina 27' by any chance?
Everybody has one:
CalebD is online now
post #34 of 45 Old 12-27-2013 Thread Starter
no. 1971 cal27
1971 Cal 27
post #35 of 45 Old 12-27-2013
Originally Posted by captain jack View Post
ok. nutserts. we used to use those at an assembly plant used to weld at. i hadn't even thought of them in years. that' a good option.
the sawzall method was what i was leaning towards, myself. sikplest way to do the job.
Rivet nuts won't provide the safety and strength of a backing plate.
Seaduction is offline
post #36 of 45 Old 12-27-2013
Is that a fuel tank vent on the sloping side aft of the stantion? If so, can you remove it and get a wrench onto the nut in question?
John
ccriders is offline
post #37 of 45 Old 12-28-2013 Thread Starter
probably true. they do rely on the stength of the material they are installed in.
1971 Cal 27
post #38 of 45 Old 12-28-2013 Thread Starter
John
i pulled that off, already, to check. it is a vent of some sort but it's only 1/4" in diameter.
1971 Cal 27
post #39 of 45 Old 12-28-2013
I confess to not having read every post, so pardon the possible redundancy.
A Beckson-style deck plate would be the cat's a** here.
I've seen them in catalogs with a cloth bag that sets into the hole.
I'd think that you could also glass in a bottom and aft end and create a small storage locker that way. Needn't be neat or finished-looking. Nobody will poke their head in.
The peace of mind you'd get knowing that your cleats are properly fastened and backed will probably be worth the effort even if you don't make a storage space. It's crazy not to have access to fastenners. And using McGyver tricks as others have suggested would work but it's often hard to know for sure how well you've secured the fastenner.
I've installed a number of those deck plates and it's easy. Just bed them with something that won't harm the plastic.
JV
VallelyJ is offline
post #40 of 45 Old 12-28-2013
Apologies. I missed the screw needed for the stern rail (pushpit). Hope you figure it out.
Virginia Cut slaneynirit@yahoo.com There's This Place... 13 10-25-2011 09:51 AM
Chimney Cut-out? QuickMick Gear & Maintenance 1 08-24-2010 06:20 PM
Cross Cut vs. Radial Cut Mainsail sailing320 Gear & Maintenance 5 07-27-2009 10:47 PM
To cut or not to cut, that is the question Omatako Seamanship & Navigation 44 03-28-2009 05:54 PM
Help- Cut/Reduced Mast Size Effect Question dougship Gear & Maintenance 2 08-15-2006 10:32 PM
