to cut or not to cut. that is the question. - Page 5 - SailNet Community
 7Likes
post #41 of 45 Old 12-28-2013
Re: to cut or not to cut. that is the question.
Cut the cleat, clear it out. See what's beneath it, i.e. any backing plate.
You may very well be able to install the new one by using LONG bolts, so they protrude down to an accessible area, and then using a basin wrench to hold the new nut on until you can get it threaded up.
If you've never seen a basin wrench, it is a "WTF did that break off?" kind of tool that plumbers use to reach up into the narrow space behind a sink, in order to tighten up the inaccessible nuts on the bottom of faucet fixtures. One size fits all, they're spring loaded to tighten down, and they'll easily go a foot or more "up" into an inaccessible pocket.
If you want to install coaming pockets, they're very useful. But if you just need access...I think a basin wrench, under ten bucks at the hardware store, is all you'll need. Or, long bolts, so you can get the nut started by hand, and then just have to screw it up several inches.
hellosailor is offline
post #42 of 45 Old 12-28-2013
azguy's Avatar
Off topic, but.......why are they called coaming pockets...???
1988 C22 Owner
azguy is offline
post #43 of 45 Old 12-28-2013
Ergh, because they're pockets in the cockpit coaming.
"Coaming
From Wikipedia, the free encyclopedia
Coaming (Originally "Coaning",) is any vertical surface on a ship designed to deflect or prevent entry of water. It usually refers to raised section of deck plating around an opening, such as a hatch. Coamings also provide a frame onto which to fit a hatch cover.
The protective metal sheeting or plating protecting against water entry into ventilator shafts in large ships is called a coaming as it suits this purpose.
The term was borrowed by the aviation industry to refer to a low rim around the opening for an unenclosed cockpit.
In addition, it is the vertical surface rising from a hatch, which forestalls the ingress of water and provides a sealing surface for the hatch cover.
Coaming also refers to the raised structure around the cockpit of a kayak."
post #44 of 45 Old 12-28-2013
RichH's Avatar
An alternative to my first recommendation, is to use extra long machine screws, "coupling nuts", and threaded rod stock. Drill down from the topside into the bottom structure of the coaming; then, counterbore the hole made in the bottom surface to allow passage of the threaded rod and attached 'coupling nut' to pass. Add nuts and washers, Caulk & Torque it all home and youre done.
Coupling nut: Coupling Nuts, Fasteners
RichH is online now
post #45 of 45 Old 12-28-2013 Thread Starter
captain jack's Avatar
Originally Posted by VallelyJ View Post
I confess to not having read every post, so pardon the possible redundancy.
A Beckson-style deck plate would be the cat's a** here.
I've seen them in catalogs with a cloth bag that sets into the hole.
I'd think that you could also glass in a bottom and aft end and create a small storage locker that way. Needn't be neat or finished-looking. Nobody will poke their head in.
The peace of mind you'd get knowing that your cleats are properly fastened and backed will probably be worth the effort even if you don't make a storage space. It's crazy not to have access to fastenners. And using McGyver tricks as others have suggested would work but it's often hard to know for sure how well you've secured the fastenner.
I've installed a number of those deck plates and it's easy. Just bed them with something that won't harm the plastic.
JV
yeah. that's the kind of access panel i was talking about.
The only rules that really matter are these: what a man can do and what a man can't do.---Captain Jack Sparrow
1971 Cal 27
captain jack is offline
Virginia Cut slaneynirit@yahoo.com There's This Place... 13 10-25-2011 09:51 AM
Chimney Cut-out? QuickMick Gear & Maintenance 1 08-24-2010 06:20 PM
Cross Cut vs. Radial Cut Mainsail sailing320 Gear & Maintenance 5 07-27-2009 10:47 PM
To cut or not to cut, that is the question Omatako Seamanship & Navigation 44 03-28-2009 05:54 PM
Help- Cut/Reduced Mast Size Effect Question dougship Gear & Maintenance 2 08-15-2006 10:32 PM
