intervention councelor(s) needed... - Page 2 - SailNet Community
 6Likes
post #11 of 24 Old 12-28-2013
Re: intervention councelor(s) needed...
In reality there almost no glass boats with structural wood. Keel sumps, mast steps, engine mounts are plastic or metal. I think Catalina used some wood for mast steps for a while, causing no end of grief. Many boats do have wood cored decks, most would agree this is the biggest problem in older glass boats. There is a theme here.
Despite this I like wood boats, and have built 3 small ones. The key is maintaining them. You must be super vigilant about fresh water intrusion, this is what kills most wood boats. If you have the time (or $), and love maintaining boats as much as sailing them, it could be a good choice.
Another option is cold molded construction, some are left unpainted. You still have to maintain a U/V resistant coating, but they can look great with lower maintainence than a "true" wood boat. Search for Nightrunner a Perry desingned boat for a great example.
baboon is offline
post #12 of 24 Old 12-28-2013
christian.hess's Avatar
I owned a herreshof h28 ketch I refit and "restored" and bought in alameda california...it had rot in the stuffing box plank and that was it...it leaked bad....as soon as that was fixed I had one of the most regarded heavy duty and sweet sailing wooden boats of all time
it was double diagonal planked teak on bronze screws and oak frames...one of the strongest combos
I varnised and sanded and did all work myself including recaulking decks, I also resealed the planks when needed etc...I popped a garboard strake when I tightened the rigging too much but I was only 19 at the time
sealed that up and loosey goosey and all was good
it came with a new yanmar inboard and I bought it for $2000, back in 99! ja!
I could sail that boat blindfolded I knew it so well
it was stronger and better built than most glass or steel boats I knew...but it was small, cramped...damp and wet and smelled like and old fart...
yet the decks were always cool...I could climb into the boat from the water with one hand cause it had like 12 inches of freeboard in the stern and it tracked like a train, and hove to like no other
it could also sail downwind with main only in 35 knots do 9 knots like a mack truck and feel safe
everything has its pros and cons though
so take that for what its worth
not all wooden boats are created equal and the same goes for any material boat you chose
avoid hearsay and research the boats you are looking at intensly, Im glad to offer any insight or help if I can
cheers
floatingPoint likes this.
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
The Following User Says Thank You to christian.hess For This Useful Post:
floatingPoint (12-29-2013)
post #13 of 24 Old 12-28-2013
One of None
deniseO30's Avatar
Originally Posted by floatingPoint View Post
keep it coming... I need to hear this. The big bad maintenance monster who lives under every wooden boat. Here's my level of delusion - I don't really buy it.
Consider exhibit PF (plastic fantastic) and WE (worm eaten).
PF and WE
wenches, running, standing and sails samie-samie
PF and WE
top deck, bright work and hatches samie-samie *
*okay some little PF have absolutely no bright work. Some aren't even finished on the inside of the hull other than hanging bunks. But a lot of boats do come with wooden hatches, seats and soles exactly as the wooden boat.
PF and WE
communication and navigation samie-samie
PF and WE
keel, rudder and bottom samie-samie
If we start with PF and WE new they'd both serve well for many years. As a class many fiberglass boats rely on their wooden cores for strength and to alleviate flex wear issues. To serve as mount points for power plants and provide backing for wenches. So most PF aren't free from wood deteriorating. Sure - there's a lot more of it in the WE. On the other hand you can get the wood on WE to dry out if it becomes water logged, but the stuff sealed up in fiberglass has to be cut out. I'm thinking this is a toss up - one particular WE might have a lot less rot expense than a particular PF.
And fiberglass fades. Now the WE can be (yea, alright must be) painted with a brush. Again every boat is different but in time the fiberglass develops cracks in the rounded corners, at flex locations etc. That is tedious and expensive to repair and the WE doesn't have any of these worries.
Eventually the wooden yacht will need to be pulled, partially disassembled (deck removed) and the inside of the hull attended to (maybe no more than repaint ). The plastic yacht doesn't have this step - but they also have the periodic major refit which covers a lot of the work you'd do on the wooden yacht.
Wood is a living thing even though you have to kill a tree to get wood. The wood will move with the weather and seasons. That works against water tight joints. So there will always be more in the bilge of the wooden yacht (at least in the size I'm talking about). Now for me, the little stream of water coming down around the mast isn't a thing. I'm probably a lot wetter out in the cockpit.
The thing is I'm not looking at a new wooden boat. They still make those you know. I think a lot of the bad rap that wood has gotten is from old boats (exactly like the one I'm looking at) which need a complete redo and someone tries to do this either without the skills, or the money, or the shop. When there are 80 year old pastic boats out there (and it won't be that long now) things might look different.
Douglas, I answered your "should you buy" thread about the 18ft Peterson. However.. the above that you wrote.. and I'm tryig to say this kindly, but it you need to learn allot more about boat building and construction of wood and fiberglass. The way wooden boats are built is hundreds of years old. The type of hull construction needs to be determined before we can advise you on more.
Here's a young lady doing "routine" work.
My last project!
deniseO30 is offline
post #14 of 24 Old 12-28-2013
One of None
deniseO30's Avatar
This guy has a whole series of you tube vids that can teach you allot!
My last project!
post #15 of 24 Old 12-28-2013
Master Mariner
capta's Avatar
Seriously, intervention?
OK, here goes. I've sailed on and operated a great many wooden vessels over the last 50+ years and I love them, each and every one.
The oldest I've sailed on was built in 1886, the oldest I've operated professionally was built in 1906 and the oldest I've owned was built in 1909 and she brought me to a safe harbor after 5 days in a SoPac hurricane at 65 years old.
You can't ignore things like annual haul outs on a wooden boat; there are creatures that eat the wood if the antifouling isn't working (or gets dinged by something you hit, but isn't even big enough you know you hit it), and even if the paint is fine, they can get through the seam compound and then into the wood. There are frames, ribs, ceiling, planking, floor timbers and butt blocks (just to name a few), all subject to rot, which is in many cases invisible, without dismantling the vessel from outside (removing planks). Wooden boats work and hog and they change shape if the rig is too tight or loose, sometimes causing problems that can cost many times the value of the boat, to repair.
Even a newer wooden boat can develop serious problems. Ask the crew on vessels like the Spirit of South Carolina and Virginia, just to name two.
Whatever fastening was used to attach the planking to the ribs can corrode, have electrolysis or just plain rust. You can spring a plank while sailing, opening a huge hole in your boat, but have no notice in advance that it might go. The seams need to be caulked periodically and I'm guessing it's pretty expensive to get it done these days, as it's a dying art (this I know for a fact, but that's a story for another post). If you get caught in heavy weather, a wooden boat, even a well caulked one, can spit out her caulking and begin to leak pretty seriously (another story).
I could go on, but perhaps this much has made that intervention successful.
Again, I love wooden boats; the feel, sea kindliness and warmth cannot be beat. But owning a wooden boat today, especially a classic, is for the very rich, and not a sailor's pastime; it's a career.
facebook.com/svskippingstone
Our Videos;
capta is offline
The Following User Says Thank You to capta For This Useful Post:
post #16 of 24 Old 12-29-2013
I disagree...if you are patient and your love for the boat EXCEEDS common wisdom youll be fine! ajajajajajajaja
slight bad joke but seriously some great deals can be had...just pay attention to the particular issues of said boat you are seeking and that applies to all forms and material boats...
cheers
ps. while caulking is a dying art that doesnt mean you cant do it
I did in panama using wool and 5200 instead of other more traditional materials...I also used syringes and boatlife or whatever pleased me at the time...
water in the bilges is a way of life...make sure its saltwater and dont let it get too high and your fine
pay attention to garboard strakes under the mast and the keelsun and keel attachment method...most wooden boats have nice hung rudders that are easily serviceable
mine floated! jajaja
post #17 of 24 Old 12-29-2013
Courtney the Dancer
jrd22's Avatar
Our boat is fiberglass (it had teak decks that we removed) and the small amount of teak (cap rail, hand rails, trim pieces, etc) require at least three times the total amount of maintenance for all the other exterior surfaces. Just sayin.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is online now
post #18 of 24 Old 12-29-2013
Lisa caulking hull - YouTube
I think he's just practicing "creative writing."
Seaduction is offline
post #19 of 24 Old 12-29-2013
Markwesti's Avatar
Hi Douglas , What kind of boat do you want ? I assume a sail boat . But what size ? How much are you willing to spend ? Are you going to be on a trailer or a slip ? I know you talked about Dana , but still I ask . One reason is that I know a guy that built one little fine sailboat (24ft.) and he keeps it on a trailer half the season . I call him Wooden Boat Bill . He helps me with wood projects, he is a craftsman/artist . He might have a wooden boat for you. If you are interested please contact me and I will PM you . Also please note I have not contacted Bill about this first , But I really like your enthusiasm . I'm sure Bill would too .
Markwesti is online now
post #20 of 24 Old 12-29-2013
I've noticed that owners of plastic boats often show interest in classic woodies. Hard to tell if it's awe, sympathy or ignorance. Done right, owning a wooden vessel puts you way above the herds of unimaginative conformists .On the other hand, it could leave you in the yard all May and June enjoying the learning curve.
christian.hess likes this.
Capt Len is offline
Tags
wooden boat
Venezuelan Navy intervention with US Sailboat provokes the loss of our vessel apueJbien General Discussion (sailing related) 31 09-14-2012 04:46 PM
Help needed in FL/NC from AK. :D AlaskaMC Boat Review and Purchase Forum 14 10-10-2010 09:19 PM
Help needed! richardrhatigan Crew Wanted/Available 3 12-20-2004 01:52 AM
