Effect of vinegar on my impeller - SailNet Community
 9Likes
post #1 of 17 Old 12-28-2013 Thread Starter
Puget Sound Pounder
kellysails's Avatar
Hello,
I would like to flush out my RW heat exchanger with Vinegar once or twice a year. I have a solution that will allow the engine to draw water from a bucket for the RW intake. I would really like to take about 3-4 gallons of clear vinegar to flush my engine and let it set in the exchanger for a week or so.
I worry that the vinegar will play havoc with my rubber impeller. I was lousy at chemistry.
Thoughts?
kellysails is offline
post #2 of 17 Old 12-28-2013
RichH's Avatar
Re: Effect of vinegar on my impeller
Vinegar (5% acetic acid) will have NO effect on the typical polymers (BUNA, Neoprene, etc.) used for such impellers. However 'soaking' a marine engine for long periods of time with 'vinegar' will accelerate corrosion/rusting of the engine's internal surfaces, slowly changing the protective 'black' rust inside the engine and exhaust manifold to destructive 'red' rust.
To 'descale' a marine engine its much better to use an 'inhibited' commercial boiler 'descaler' such as RydLyme™, etc. ......... and it will only take an hour or so to do and wont 'dissolve' a wee part of your engine in doing so. RYDLYME Marine: The Ultimate Biodegradable Marine Descaler! | RydLyme Marine
Use the vinegar on your salads instead. ;-)
RichH is offline
post #3 of 17 Old 12-28-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
I used vinegar to clean my raw water pump and thought of running some through the engine. That Rydlyme product looks pretty good. Looks like that stuff can really clean up any deposits quicker.
christian.hess likes this.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #4 of 17 Old 12-29-2013 Thread Starter
Puget Sound Pounder
kellysails's Avatar
Wow! That about says it all. I am soo glade I asked. Thank you!
post #5 of 17 Old 12-29-2013
christian.hess's Avatar
do it your fine
I like apple cider vinegar
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #6 of 17 Old 12-29-2013
Skipper Jer's Avatar
Hmmmm...wonder if CLR, Calcium, Lime & Rust Remover, would be a suitable substitute?
Jelmar | We Clean More Than You Think - Home
Disclosure: I have no financial interest in Jelmar, the maker of CLR. When I can find a suitable landlubber product that replaces a marine product I use it.
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
post #7 of 17 Old 12-29-2013
Old as Dirt!
svHyLyte's Avatar
I have been using Rydlyme in both our engine RW cooling system and Air Conditioning heat exchanger for several years to good advantage. It works. Regarding your raw water impeller, however, it is wise to replace the impeller no less often than annually or every 200 hours to avoid lost vanes/blades which can really ruin your day.
svHyLyte is offline
post #8 of 17 Old 12-29-2013 Thread Starter
Puget Sound Pounder
kellysails's Avatar
MaineSail pointed me towards Rydlyme a while back. Oddly, it is really hard to find it in the PNW. My nearest dealer is selling it out of the Bremerton Yacht Club as a side business. It would also require an external pump to circulate it through the system. I was hoping for a somewhat simpler process using cheap house hold products and utilizing the impeller to drive the product through the engine. Oh well, thanks for the info, much appreciated.
post #9 of 17 Old 12-29-2013
Old as Dirt!
svHyLyte's Avatar
A similar product that you may be able to find locally is (click on) "Barnacle Buster"
A method I use for the heat exchangers on our engine and AC system is a 5 gallon bucket coupled with a small inexpensive submersible bilge pump. One connects the discharge line from the pump to the injection nozzle on the discharge side of the heat exchanger (temporarily disconnecting the tube to the mixing elbow in the case of the engine) and a return hose from the input side of the heat exchanger back to the bucket (the reverse flow helps clear debris out of the tube bundles). The solution of RydLyme (or Barnacle Buster) and water is then circulated by the pump which can be run off the ship's batteries with jumper cables. One can test the efficacy of the solution by dropping a small piece of shell in the solution. If the solution "fizzes" up around the shell, it's still viable. While its difficult to know precisely how long one needs circulate the solution to completely remove scale, there are time guide lines on the web-sites for both solutions. In our case, I usually let the pump run for 4 or 5 hours with solution and then follow up with fresh water for awhile. One trick is to tie a ladies stocking over the end of the discharge hose to capture debris and suspend the pump several inches above the bottom of the bucket such that it does not suck up and recirculate any sand/debris that is washed out and escapes from the ladies stocking "filter". You may be surprised at the increased through-put in your systems once you've done this exercise.
FWIW...
svHyLyte is offline
The Following User Says Thank You to svHyLyte For This Useful Post:
kellysails (12-30-2013)
post #10 of 17 Old 12-29-2013
Old enough to know better
The MSDS shows different ingredients for these products. CLR is considered an OSHA hazard but Ridlyme is not. I would not use CLR as it is really strong stuff.
I think he uses the pump so he can do it without the motor running, if you have a way to circulate it with the engine running without overheating I don't see why you could not use the it. Do be careful as it says not to over heat it, past 180 degrees, not sure what happens if it happens and remember there may be spots on a running cooling system well over that temp.
miatapaul is offline
Effect of the effect of the BP oil spill on Gulf Coast marine industry knothead Cruising & Liveaboard Forum 0 09-13-2010 08:23 PM
What's better than putting vinegar in your heads? Bene505 Gear & Maintenance 12 06-08-2010 02:03 PM
Effect of grounding. chris_gee Sailboat Design and Construction 14 09-06-2008 07:56 AM
