Teak cockpit table treatment question - SailNet Community
 2Likes
post #1 of 13 Old 12-29-2013 Thread Starter
Zanshin's Avatar
I have a solid teak cockpit table with two teak folding leaves. These are untreated, as is the rest of my teak; but since this table gets used for eating and other things it soaks up grease and other stains in its current state.
I would like to find a long-lasting and low maintenance covering for the table. While varnish is the classic approach, I am afraid of it chipping and thus becoming a maintenance chore.
What options are there out there apart from varnish? The picture below was taken before the table was cleaned up with a bit of water and oxalic and shows stains from food and from an Aloe Vera plant pot.
Zanshin is online now
post #2 of 13 Old 12-29-2013
Re: Teak cockpit table treatment question
Although I prefer varnish, here is an alternative: System Three: Projects: Bartop Coating with MirrorCoat
I've never used it.
Seaduction is offline
post #3 of 13 Old 12-29-2013
azguy's Avatar
What about teak oil...??
It's easy to throw a coat on when it starts looking shabby..
1988 C22 Owner
azguy is offline
post #4 of 13 Old 12-29-2013
You can apply just a few coats of highly thinned varnish, which doesn't build to a gloss, but will seal and protect. Looks satin. I also like a product named Bristol Finish, which can be applied the same way, but thinned with acetone and dries in one hour. Big advantage.
You're going to need a good sanding before applying anything.
Flybyknight likes this.
Jeanneau 54DS
Minnewaska is offline
post #5 of 13 Old 12-29-2013
Tartan 27' owner
CalebD's Avatar
Least amount of work:
light sanding
rub down with teak oil now and again
Everybody has one:
CalebD is online now
post #6 of 13 Old 12-29-2013
An alternative solution would be a cover that matches your canvas. Varnish the table to perfection and then make a cover to slip on over it when its not in use, thus protecting it from weather, etc.
post #7 of 13 Old 12-29-2013
bigdogandy's Avatar
Dock
I have Cetol on mine and I think it is great.......it had been varnished previously and the varnish was peeling badly. I scraped and sanded it down to bare wood, put on 3 coats of Cetol and then 2 coats of Cetol gloss and now more than 4 years later it still looks great and beads water like when it was brand new.
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is online now
post #8 of 13 Old 12-29-2013
Right on there Andy. I actually use Cetol plus Cetol Gloss. I thought of them as varnish. Technically, I don't know if Cetol is varnish or not. I use Cetol extensively on my IP.
post #9 of 13 Old 12-29-2013 Thread Starter
Zanshin's Avatar
Thanks for the suggestions! Is the Bartop Coating UV-Resistant? I couldn't see that on the web pages. The Cetol looks quite nice as well. I might go the simple route and sand it flush and use placemats with greasy food. I do plan on covering the table when not in use in the future, that pitting came from storage over the summer when the table was not covered and exposed to the hard rains.
post #10 of 13 Old 12-29-2013
scurvy dog
delan's Avatar
I've used hundreds of gallons of bartop (usually called table top) resin over the years, it is not uv resisitant.
But, for my cockpit table, I sanded it, poured it with table top resin, let it cure for a few weeks indoors, out of any direct sunlight, then gave it three coats of awlspar, that's awlgrips spar varnish, which has a ton of uv inhibitors. Five years later, being in direct sunlight in Miami, it has a couple of dings and chips in it, so it's ready for a light sand, and a recoat.
the reason we love it for bars, is that after 5-10 years of hard service, a light sand takes care of the cigarette burns, and the cranberry where the drinks are made, then one pour of the resin (it's poured on, not brushed or rolled) and it's like new.
Restauranteur
Mako 236
Shamrock 26
Schucker 44 Cutter
Dyer Dhow
delan is offline
Tags
cockpit table , teak , varnish
Best teak treatment.... Frozensurfer Gear & Maintenance 33 03-08-2013 01:19 PM
Folding teak cockpit table-First seen? windcatcher General Discussion (sailing related) 8 09-20-2012 01:26 AM
Ok next question.. cockpit table old-sailer C & C 3 10-04-2011 03:28 AM
Teak Treatment in the Tropics brainstormers Gear & Maintenance 5 02-26-2005 12:21 AM
Treatment for Teak Deck docket Gear & Maintenance 1 04-17-2002 05:41 PM
