Keel Joint on Hunter 25.5 - SailNet Community
post #1 of 2 Old 03-21-2005 Thread Starter
Hi all,
any suggestions on how to fix the rusted/chipped keel joint? I heard it''s a common thing on hunters. I just wanted to see if anyone had done it and what is best way of fixing the rusted keel at the joint.
thanks
neil
neil123 is offline
post #2 of 2 Old 03-23-2005
Remove the rust by sanding or chemical means. www.yachtpaint.com Interprotect primer 2000E
http://www.westsystem.com/frames/tier1/usingepoxy.htm
I am useing 404 filler 105 epoxie 206 hardner.Make sure the keel bplts are ok torque them and prep sand and bottom paint. The Interprotect needs to be tacky where it will leave a thumb print but not stick to your skin. That is when you put your bottom paint on if you let it dry you have to remove it and start over.
sailnaway is offline
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 17 07-30-2014 09:23 AM
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 11 05-06-2011 04:39 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 09:32 PM
Keel Anxiety! Spang Boat Review and Purchase Forum 8 06-19-2006 03:09 PM
Short Keel vs Normal SEAJM General Discussion (sailing related) 1 03-12-2003 02:13 AM
