Blogs
User Name
Old 03-21-2005
owenmccall owenmccall is offline
owenmccall is on a distinguished road
Strange keel zinc
My new (to me) boat is fitted with an odd kind of keel zinc. Just below where the (external lead) keel is bolted to the glass keel root there is a 4" dia. zinc disk fastened to the lead with 4 short ss wood screws. In the center of this disk is a fifth hole filled by a large set screw. If this set screw is removed from the zinc disk a hole is revealed that communicates with the bilge sump. This is great for draining the bilge when the boat is on the hard, but I worry that when afloat, if (when) the zinc disk degrades THE BOAT WILL SINK! Has anyone else seen such a set-up before? Is this (yet another) bad idea of the P.O.?
Owen McCall
Old 03-23-2005
Billpjr Billpjr is offline
Billpjr is on a distinguished road
Strange keel zinc
That''s one way for bonding thru hulls, etc but a bad installation practice if the zinc can waste away and let water in. Many boats run wire inside the bilge to the motor and tap off it''s zincs. Most out there don''t even protect their thru hulls and are the ones that usually sink at the dock.
Display Modes
vB code is On
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 15 03-20-2008 05:36 PM
reducing keel/adding fin? abacosol Gear & Maintenance 9 07-01-2007 10:32 PM
Keel Anxiety! Spang Buying a Boat 8 06-19-2006 04:09 PM
Short Keel vs Normal SEAJM General Discussion (sailing related) 1 03-12-2003 03:13 AM
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 7 11-07-2002 10:34 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
