Blogs
User Name
Old 04-12-2001
Capt.CarroleWard Capt.CarroleWard is offline
Capt.CarroleWard is on a distinguished road
Spartite 2000 mast wedge replacement system - need info
We have a 1975 40''Northstar 80/20 Ketch (also know as the Spice Islander and Hughes 40)- and would appreciate any personal experience with the Spartite 2000 Mast Wedge Replacement System. Does it replace the rubber partners - does it leak and/or does it need a mast boot on top of it? Does it transmit shocks from mast to hull or hull to mast? Our main mast is massive - Sparkman Stevens Design We will be gone for about 6 weeks - from April 14 - so any requested response will be delayed until we get back. Thanks in advance for any info.
Old 04-16-2001
tiz_1 tiz_1 is offline
tiz_1 is on a distinguished road
Spartite will replace the rubber blocks at the partners. It does leak water. It is also damaged by sunlight. To protect from sun and reduce water leakage, cover with mast wrap tape or mast boot. I also silicone around the mast-spartite joint. There should be no "shock loads" from the mast to deck since the mast will not move laterally in the partners - a big improvement over wood or rubber blocks. It should not matter how large the mast is, only the size of the gap between the mast and deck. You will need to estimate how much to use to fill the space per the instructions.
Great product. Fairly easy to install. Have had mine for 4 years - CAL40.
--Kevin
Old 05-30-2001
tmcahn tmcahn is offline
tmcahn is on a distinguished road
ditto on spar tite. installed mine in 97, siloconed around the top and installed a boot cover--no leaks no shifting, great product--did it myself, tmc
Sponsored Ad
Display Modes
vB code is On
Deck stepped Mast-Always Bad ? Mrs Mutiny Buying a Boat 23 02-01-2008 11:05 AM
which 38ft boat? bluewaterdreamer Buying a Boat 10 10-03-2007 01:54 PM
30ft Catalina BigRuss Buying a Boat 3 09-09-2006 06:33 PM
what mast? jrwright Buying a Boat 3 03-14-2004 09:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 07:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
