Vacuum Sealing Gear and Supplies - Page 3 - SailNet Community
 8Likes
post #21 of 36 Old 01-02-2014
Old enough to know better
Re: Vacuum Sealing Gear and Supplies
Originally Posted by SVAuspicious View Post
You can also seal wine bladders. I've carried lemonade and various juices in repurposed wine bladders.
That is a good idea. I could see even reusing them for wine. You have a much better selection in bottles.
miatapaul is offline
post #22 of 36 Old 01-02-2014
From the horse's patootie:
Bags
Can I boil in Ziploc« brand Bags?
No. Ziploc« brand Bags are not designed to withstand the extreme heat of boiling.
And to think we used to heat tin cans of beef and beans right in the fire, never knowing that BPA existed.
hellosailor is offline
post #23 of 36 Old 01-02-2014
Minnesail's Avatar
Bags
212║F is extreme heat?
The manufacturer may not recommend boiling, but it works just fine. It might leach crazy plasticizers into the food, I'm not sure, but the bags hold up well in a pot of boiling water. I've done this several times and have experienced only mild side-effects, including ankle bearding, wandering nipple, and brain tooth.
But in any case, vacuum sealer sounds like a much better idea. I'm sure the sous-vide bags are designed to be used at temperature and not plasticize your food.
dvuyxx likes this.
Catalina 22
on a starboard tack
Minnesail is offline
post #24 of 36 Old 01-02-2014
Bags
I think Mr. Ziplock is afraid you'll have the bag touching the bottom of your pot, which would exceed the 212 of boiling water. They also recommend you don't boil things in the "zip-n-steam" bags, which are expressly designed to withstand boiling temperatures...
jeremiahblatz is offline
post #25 of 36 Old 01-02-2014 Thread Starter
s/v Tiger Lily
dvuyxx's Avatar
Originally Posted by jimgo View Post
David, if you're using the mylar chip bags for your socks, they may be a little salty and crunchy when you go to wear them. You might want to turn the bag inside out next time.
I only use salt n' vinegar chip bags. They fight athletes' foot.
jimgo likes this.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #26 of 36 Old 01-03-2014
vtsailguy's Avatar
Another vote for vacuum sealer awesomeness.
Good candidates are either things that can compress well, things that are messy/small or things that can be stored for emergencies. I tend to use zip locks for everyday stuff as the sealer bags are so expensive. The space bags I use for big stuff
Emergencies
A few diapers
Small medkit
Home made mre
Home made survival kit
Messy
Plastic fishing bait (eg gulp)
Dried foods
Compressible
Set of clothes
Couple of tips
If something can get "scrunched" by the vacuum (eg clothes, documents), insert a bit of cardboard to keep the shape.
Things that had a bit of fluid, like meat, never could seal as the liquid would be drawn out. Sea lamely now has a special bag that stops this and they seal better.
I wish their was a 12V version and the bags were more available in huge Caribbean!
Has anyone tried the new handheld "portable" version?
Three mini-pirates scour the Caribbean Seas with stops for ice cream and legos
Latest blog post:
vtsailguy is offline
post #27 of 36 Old 01-03-2014
chucklesR's Avatar
Wait a minute...
You are saying socks aren't normally salty and crunchy?
Over the years we've used various vacuum sealers; we will be taking one will us when cruising.
Thanks for the ideas on med's, doc's and such.
chucklesR is offline
post #28 of 36 Old 01-03-2014
vtsailguy's Avatar
Hot of the press!
I just found this on eBay, and bought it. Perfect for sailing, no electric needed
Brand New Hand Held Super Sealer Vacuum Sealer | eBay
Latest blog post:
post #29 of 36 Old 01-03-2014
MikeOReilly's Avatar
Based on some of the enthusiastic comments here I just ordered my Foodsaver sealer. I got the 12-volt version thinking that might be useful on board. So thanks all.
Why go fast, when you can go slow.
MikeOReilly is offline
post #30 of 36 Old 01-11-2014
vtsailguy's Avatar
I didn't know they had a 12V version, cool
Three boys, 200 sq ft of fiberglass, tropical beaches
www.sailingwithkids.net
Latest blog post:
Tags
bagging , food storage , sealing , storage , vacuum
Looking for Sailing Supplies store bigfld63 Gear & Maintenance 0 03-10-2010 11:00 AM
Cleaning Supplies pmpcc herSailNet 13 11-21-2009 12:23 PM
wood boat building supplies RManning66 Sailboat Design and Construction 6 02-10-2009 10:05 AM
MEDICAL SUPPLIES/DRUGS/ETC. FROM WHERE? cdennyb Provisioning 30 11-23-2007 12:31 PM
Procuring Med-Kit Supplies William Mahaffy Seamanship Articles 0 03-23-1999 07:00 PM
