Whale in line pump trouble - SailNet Community
post #1 of 5 Old 12-30-2013 Thread Starter
Hi all, i'm new to forum. Thanks for having me.
I have an odd problem with my whale in-line pump i can't diagnose or find an answer here for:
I use a 12 volt inline pump as my main galley pump, I know they're intended to be supplemental to a larger pump, but my boat came with this set up and it worked fine until recently.
Now, though, when i press the foot pedal, it functions fine for about five seconds, and then the water flow stops and the pump seems to be running dry. If i wait another 15 seconds or so, it runs again, but only for another five seconds, and so on and so on.
I checked the intake hose, and the water runs strongly out (it's below the tank level), so there doesn't seem to be any blockages. When it runs for the 5 seconds, the water comes out clean and full strength, then stops instantly. It doesn't trickle out or anything.
It's possibly notable that it did start doing this after a cold snap in which temps got down to about 20 at night. However i never operated the pump until the temperature warmed back up a few days later.
Any ideas?
Thanks,
Steve
StevenPH is offline
post #2 of 5 Old 12-31-2013
rugosa's Avatar
Re: Whale in line pump trouble
Pull the pump out & bench test, looking for pump leak, good chance you have a hair line crack that opens when the pressure builds. May also be in the faucet fitting.
rugosa is offline
post #3 of 5 Old 12-31-2013
rbrasi's Avatar
Also check the air valve. It should run from somewhere on top of your tank to a deck vent. If clogged, it will stop flow.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #4 of 5 Old 12-31-2013
Delta-T's Avatar
Is this an automatic pump with a integral pressure switch?
If so, I'm wondering if you have some ice still in the line past the pump to the facet?
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #5 of 5 Old 01-01-2014
Master Mariner
capta's Avatar
If this is the double action foot operated diaphragm Whale galley pump, you probably have a ruptured diaphragm. No biggie, they should be available at most chandlers. If it's not, post a pic.
facebook.com/svskippingstone
Our Videos;
capta is offline
Manual Bilge Pump - Plastimo or Whale Quickstep192 General Discussion (sailing related) 2 10-17-2011 10:57 AM
Fresh water foot pump (Whale) leaking josrulz Gear & Maintenance 4 05-18-2009 08:37 AM
Inverted bulkhead mounted whale pump jumaggafanny Gear & Maintenance 3 03-24-2009 04:04 PM
Whale Gusher Pump Question harbin2 Gear & Maintenance 24 01-15-2009 02:54 PM
bilge pump trouble sailhog Gear & Maintenance 7 06-20-2007 10:11 PM
