Waterline higher - SailNet Community
post #1 of 3 Old 03-28-2005 Thread Starter
Waterline higher
Hi there..
I have a 1985 Laguna 30 (like a Catalina) and it seems that my water line is getting higher as when it sits in the water, the water covers above the bottom paint (mainly in the bow and stern).
- I don''t think it''s weight as there isn''t much we keep in the boat
- Also, when looking at it in dry dock, it seems that it curves
I have had this boat for 5 years. What do you think is the problem. I have had some leaks in the forward part of the keel (repaired)...do I have moisture retaining?
Thanks to hear from anyone with a suggestion.
Thom Gault-
Chicago
tjgault is offline
post #2 of 3 Old 03-29-2005
Señor Member
TrueBlue's Avatar
Waterline higher
Thom,
From a non-expert''s point of view, if the bottom has developed blisters within your five years of ownership, it is possible that water intrusion within the laminate layers could add excessive weight. This, of course, would result in a higher waterline.
Otherwise, with only the bow & stern dropping and a noticible increase in hull curvature, some deformation may be occurring. If you suspect this may be the case, a marine surveyor or naval architect may provide more insight.
Steve
TrueBlue is offline
post #3 of 3 Old 03-29-2005
Waterline higher
Are you in a marina or anchored near a stream or river? I have noticed that after heavy rainstorms the fresh water coming down tends to lower salinity of the seawater for a while, and my boat will sit slightly lower in the water.
Thermal is offline
Can a Bristol 32 Circumnavigate? mmcdan Boat Review and Purchase Forum 55 02-07-2017 08:43 PM
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
What can you tell from the numbers? brazilnut Boat Review and Purchase Forum 10 07-01-2009 04:09 PM
LP below waterline? birdboat Gear & Maintenance 1 01-21-2003 02:22 PM
Why L?D has nothing to do with seakindliness Jeff_H Boat Review and Purchase Forum 7 02-19-2002 03:34 PM
