Origo alcohol/electric troubles - SailNet Community
post #1 of 3 Old 03-29-2005 Thread Starter
I am the ''current owner'' of an Origo 110 volt AC and Non-Pressurized alcohol stove; old style 4500(rotating knobs). When I wired it up, I found one electric element would not heat up. To diagnose further, I swapped the controls (repairing a cracked connector) and found that now both elements will warm. Initially the stove will heat about 1 minute & then the GFI opens. Reset, it lasts about 30 sec; next 10 sec; then immediate. Both circuits, alone & together. Any ideas? My E-Mail to Origo is unanswered...
jackmace is offline
post #2 of 3 Old 03-31-2005 Thread Starter
*New info*
OOPS my bad... the stove was not plugged into a 20 AMP circuit... the GFI I was testing with was only rated for 15 amps. Sorry for asking for help on something so simple... I am embarassed to have asked.... -Jack
jackmace is offline
post #3 of 3 Old 04-01-2005
Seņor Member
TrueBlue's Avatar
Don''t be embarrassed jack . . . there just may be sailors out there who could benefit by your discovery.
TrueBlue is offline
Origo stoves JIO Gear & Maintenance 23 12-03-2009 06:57 PM
Origo 2 burner..where to locate used? halyardz Gear & Maintenance 2 11-21-2004 11:27 AM
Starting troubles raybies Gear & Maintenance 4 05-14-2003 08:24 AM
