Just the Keurig won't work - Page 4 - SailNet Community
 32Likes
post #31 of 51 Old 01-03-2014
Learning the HARD way...
eherlihy's Avatar
Re: Just the Keurig won't work
Originally Posted by chucklesR View Post
Ya'll need to forego all that fancy smancy stuff.
Just grab a bean and chew like nature intended. If your teeth can't handle it just take a pinch of grounds and put it between cheek and gum
Having said that, I use instant on the boat (and yes, sometimes I just eat it straight). My dentures don't like the crunchiness of the beans).
I was with you until....
INSTANT!?!
That would get you ejected from my boat...
eherlihy is offline
post #32 of 51 Old 01-03-2014
this
and this
will not only solve your problem, but you'll have better coffee.
Multihullgirl is offline
post #33 of 51 Old 01-03-2014
christian.hess's Avatar
simplicity rules
end of story...now if hooked up to shore power Id have an espresso maker, regular drip and what ever tea thing the lady wants
Im trying to quit coffee this year so maybe the op can try that too! jajajaja
kidding
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #34 of 51 Old 01-03-2014
bljones's Avatar
Instant on the boat is better than a keurig cup on the dirt.
and a cup of instant brought to you in the cockpit halfway through a early morning watch is better than a keurig you cannot reach.
It's 5 o'clock somewhere:
bljones is offline
post #35 of 51 Old 01-04-2014
JimMcGee's Avatar
That's a good tip about the temp switch!
Our little Keurig mini tucks up in an alcove on the counter, stays put when things are rough and hasn't given us a lick of trouble since we bought it in 2008.
Obviously the taste varies depending on what kind of coffee you use (emeril's bold is good) and bottled water makes a big difference. And it makes hot chocolate and flavored tea for the wife who's not a coffee drinker.
I'm switching to the $3 Melita away from the dock. The French press is a pain to clean up and I'm not thrilled about glass on board.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #36 of 51 Old 01-04-2014
Jim mcgee,
the Thermos French press I pic'd above is not only all metal, but is insulated.
Personally I'd rather just rinse some grounds than have filters and little plastic cups to deal with on the boat (extra trash); something to think about, anyway
post #37 of 51 Old 01-04-2014
We use an automatic drip maker aboard, which runs easily off the inverter. I really like coffee made with the manual cone and a pot of boiled water, but I am OCD about a lit stove and it keeps me in the galley until finished, so I prefer the electric auto where I can go sit and read or go above. If anything, I wish I had a bigger one for when we have more than 4 aboard. 10 cups is small, but a stainless carafe is mandatory.
We have the mesh metal grind basket, but never use it. Cleaning is a real PITA! You knock most of the grounds into the trash, but then either litter the sink with the rest or have to wipe them out with a paper towel that gets tossed or a rag that gets filthy. We use the #4 paper filters, which we just pick out and toss. Easy peasy.
BTW, we are serious coffee snobs at home. Grind our own beans with a Rancilio Rocky and brew espresso with a Rancilio Silvia. I'm on my second right now.
However, on the boat, all coffee tastes better.
christian.hess likes this.
Jeanneau 54DS
Minnewaska is offline
post #38 of 51 Old 01-04-2014
no longer reading SailNet
Alex W's Avatar
Aeropress has no glass bits, makes better coffee than the french press, and takes up very little room when not in use. I like them so much that I now have 3 of them: home, work, boat.
Multihullgirl and Scott McD like this.
Alex W is offline
The Following User Says Thank You to Alex W For This Useful Post:
Multihullgirl (01-07-2014)
post #39 of 51 Old 01-04-2014
come down to el salvador....the unknown coffe capital of central america
seriously good stuff
Id be happy to send some up for you guys
and the best thing
its cheap compared to ethiopian, indonesian, etc...
post #40 of 51 Old 01-05-2014
outbound's Avatar
Minnie try a vario baratza when your rocky gives out. Same money and size but you can actually clean the d-mn thing and not worry about cross threading anything. Also doesn't heat the beans when grinding so get a less bitter grind.
Been known to freeze home ground beans wrapped in paper towel. Want coffee when its bumpy put paper towel/coffee in bottom of thermal cup and wedge down with spoon until saturated with hot water. When done consuming put in sink until cool and pick out paper towel. No messy clean up.
Minnewaska likes this.
s/v Hippocampus
Outbound 46
outbound is offline
Auto bilge won't work Fau Gear & Maintenance 9 08-13-2013 10:24 PM
Depth guage won't work Fau Gear & Maintenance 2 07-29-2012 12:17 PM
I won, I won OPTIMANIA General Discussion (sailing related) 43 03-03-2008 06:41 PM
What WON'T you do yourself? CLucas Gear & Maintenance 43 02-23-2008 02:46 PM
