Cellular phone amplifiers & antennas - SailNet Community
post #1 of 2 Old 04-07-2005 Thread Starter
I am considering installing a Digital Antenna Cellular Amplifier with a 9dB gain mast mounted antenna and a 2nd inside antenna (to permit wireless connection to phone) on a 38 foot sailboat. I have a 50+ ft. mast (the min. distance separation 20'') between antennas but need to make sure there is sufficient attenuation of the signal from the mast mounted antenna so as to not cancel out the inside antenna (the deck is apparently not sufficient). Has any one ever installed such a configuration or have any suggestions on how to increase the attenuation of the signal from the exterior antenna above the inside antenna?
Thanks.
John Lubimir
Sabre 38-II
jlubimir is offline
post #2 of 2 Old 04-24-2005
You might try looking at this place.
http://boatantenna.com/index.html
sidney777 is offline
Cell phone jmcornelis Gear & Maintenance 1 02-08-2005 01:33 AM
ssb/pc to phone calls duke Cruising & Liveaboard Forum 3 02-19-2003 08:13 AM
FYI: GPS interference from TV antennas gstraub Gear & Maintenance 0 01-10-2003 08:36 AM
