Water inside mast - SailNet Community
post #1 of 2 Old 04-14-2001 Thread Starter
Water inside mast
I have an access hole on the side of my mast about 4 inches from the bottom of the mast. about 1 inch square. While looking inside I found that there is about 2 inches of water lying in the bottom. What is the fix? Drill a couple of small holes at bottom of mast or what. Thanks
JerryFurnas is offline
post #2 of 2 Old 04-14-2001
paulk's Avatar
Water inside mast
Sounds like that should work. When you go to do it you may find some holes in the mast''s baseplate that got filled in somehow, and just need reaming out.
paulk is offline
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 08:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 01:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 06:33 PM
what mast? jrwright Boat Review and Purchase Forum 3 03-14-2004 09:19 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 07:08 PM
