Outboard fuel storage - SailNet Community
post #1 of 3 Old 04-11-2005 Thread Starter
I''ve been looing at a lot of boats and haven''t seen a very safe way of storing a gasoline jug for the outboard. What do most people do? There''s usually a draining locker for the propane tank(s), but I haven''t really seen a locker that looks safe for gasoline.
leelocke is offline
post #2 of 3 Old 04-11-2005
Seņor Member
TrueBlue's Avatar
This may be a unique feature to my boat, but a possible retrofit for some sailboats with open aft deck areas, such as abaft of center cockpits or over swim platforms.
On the raised aft deck of my Nauticat Pilothouse Ketch, are two solid teak bench boxes flanking the aft helm station. Each bench-box measures about 42"l x 18"w x 20"h, is firmly screwed to blocks secured to the teak decking and has a hinged grated teak lid, under the upholstered top cushion. The bottom panel is vented.
I have found these boxes to be very versatile for storage of cruising gear while under way. One bench contains my spare alum. propane cylinder (the cylinder in use has a designated locker within the starboard side deck steps) and the tender''s outboard gas jugs . . . since the teak grating allows for required air circulation. The other bench works well for temporary stowage of PFDs, a small cooler, docking lines & chafing gear.
Steve
TrueBlue is offline
post #3 of 3 Old 04-12-2005
Gas fumes are heavier than air so you do need to be careful. Ive always just used a jerry jug the type than can be found at West Marine for about $12. They hold 5 gals each, have 2 handles (one to carry it and one to pour) and can be lashed onto stantions or whatever. I guess its not an elegant solution but it works for daysailors all the way up to ''round the world cruisers..
hamiam is offline
Heaters: diesel or solid fuel? Seagypsywoman Gear & Maintenance 9 12-29-2004 02:22 PM
outboard fuel pump strength wgwl13736 Gear & Maintenance 5 08-16-2004 08:03 AM
old diesel fuel capedoryus Gear & Maintenance 1 12-17-2002 07:14 AM
Beginners with Fuel Storage MDemaree General Discussion (sailing related) 5 04-21-2002 07:57 PM
Yanmar 2QM15 Bleeding Fuel System - HELP shipley Gear & Maintenance 5 03-11-2002 07:21 PM
