Turn Buckle Threads - SailNet Community
post #1 of 10 Old 04-11-2005 Thread Starter
Turn Buckle Threads
What does everyone use to lubricate the turnbuckles for the standing rigging. I am always looking for new ideas.
Alan
"UNABATED"
P424
aphil138 is offline
post #2 of 10 Old 04-11-2005
Moderator
Jeff_H's Avatar
Turn Buckle Threads
Lanacote
Jeff_H is online now
post #3 of 10 Old 04-12-2005
Turn Buckle Threads
Lanacote is the stuff to use.
while you have them without cotter pins . try putting in a machine screw with a nylock instead of the pin.
easier to remove, doesn''t cath on things,
doesn''t need rigging tape.
fair winds,
eric
kimberlite is offline
post #4 of 10 Old 04-12-2005
Moderator
Jeff_H's Avatar
Turn Buckle Threads
With all due respect, using a bolt instead of a clevis probably is not a great idea. Clevis pins are generally forged while bolts are not. In other words, a normal bolt of equal diameter has substantially less strength than a clevis. Also you need to worry about using excctly the right length bolt so that you do not end up with threads bearing on the jaws and so that the bolt is tight enough not to allow the jaws to spread.
post #5 of 10 Old 04-12-2005
Seņor Member
TrueBlue's Avatar
Turn Buckle Threads
I must agree with Jeff re: the suggestion of using bolts instead of cotter and clevis pins on standing rigging turnbuckles. If the look of tape offends you, use turnbuckle covers.
Steve
TrueBlue is offline
post #6 of 10 Old 04-12-2005 Thread Starter
Turn Buckle Threads
Lanacote.... Thanks
BTW,I would never use a bolt in place of a clevis. Way too soft even a hardened one is only case hardened.
aphil138 is offline
post #7 of 10 Old 04-13-2005
Turn Buckle Threads
I got the impression that Kimberlite was suggesting using a macine screw instead of the cotter pin, not instead of the clevis...
Thermal is offline
post #8 of 10 Old 04-14-2005
Moderator
Jeff_H's Avatar
Turn Buckle Threads
I think that the idea of a machine screw instead of a cotter only makes sense on a very big boat where you mught be using 1/8" diameter cotter pins or bolts. Even there there are issues. The hole for the cotter pin should be very close to the jaw so that the jaws can not spread wider. If you use a bolt, the nut will need clearance in order to be free to turn which means that there will need to be more clearance than is normal for a cotter pin.
post #9 of 10 Old 04-14-2005
Turn Buckle Threads
jeff,
i meant for machine screws and nylocks to be used instead if cotter pins.
The nylock and screw serves the same function as the cotter pins - to keep the turnbuckle from turning. it is also beneficial as there is nothing to catch and
you do not have to use tape. the tape can lead to crevice corrosion and is nasty looking. works great on small and large boats.
fair winds,
''eric
kimberlt is offline
post #10 of 10 Old 04-14-2005
Turn Buckle Threads
to clarify even further- use the bolt/nylock setup only in the turnbuckle.
eric
kimberlt is offline
prop won''t turn harley2007 Gear & Maintenance 2 07-05-2003 02:56 PM
Atomic-4 Hard to turn over cusacktf1 Gear & Maintenance 4 11-12-2001 09:03 PM
