Towing and trailer questions. - Page 2 - SailNet Community
 2Likes
post #11 of 20 Old 01-06-2014
4KSB driver.
SHNOOL's Avatar
Dock
Re: Towing and trailer questions.
Ok, Bruce, not to be all one up or anything.
But I launched and retrieved with no extension from the bumper of my pickup, I have a 4'2" keel. hehehe... Very steep ramp! NO I don't want to do it again (this is my second season doing that).
I'm on my 3rd attempt to setup a set of heavy duty dolly wheels, I think it's time I moved on to installing an extendable tongue on the trailer.
Anyway, if we are talking about a shoal keel, launching is less an issue than you'd think. Just need a decent ramp, but true if it's a shallow ramp you'll need the extension, good news is they aren't rare..
Another boat trailer to consider is the Capri 22 trailer (again if you are talking a shoal keel Oday 23). Also good news is most of the first generation ones had tongue extensions built in.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #12 of 20 Old 03-13-2014 Thread Starter
utchuckd's Avatar
There's a trailer that's hit craigslist locally that I'm going to look at. It would need a little modification to fit my boat to it, but it's a good enough buy possibly to justify it if it's in good enough condition. One question tho, it has rollers down the middle of it, are those ok or will I need to replace with a full length board for the keel to sit on?
Donnie Harris
1980 O'Day 23
utchuckd is offline
post #13 of 20 Old 03-13-2014
Group9's Avatar
Originally Posted by sailortjk1 View Post
Check the towing capacity in the owners manual before any purchase and make sure the towing capacity exceeds the combined weight of the boat trailer and motor.
O'Day 23 weighs how much?
7,000lbs or so.
I would think a 1/2 Ton Pick up or SUV should pull it.
Are you planning on launching and retrieving at a ramp? Than I would make sure you have a 4WD vehicle for the slippery slimey ramps.
And remember,towing is very stressful on the transmission as well,so that should be checked.
The transmission is almost always the weakest point in a vehicle used for towing (with brakes next). If you are going to tow any distance at all, it's worth it to invest in a transmission cooler, and surge or electric trailer brakes.
That, and make sure you have a good hitch (not the one that is part of the bumper).
I tow a center console boat that weighs 6000 pounds. You know it's back there.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #14 of 20 Old 03-13-2014 Thread Starter
utchuckd's Avatar
I bought a truck about a month ago, found an older 1 ton pickup, heavy duty fame, big frame mounted hitch, trailer brake box, it could pull a house if I hooked it up, but in my price range a little older and uglier and more functional was worth more than a little newer and prettier. I do need to double check that transmission tho, thanks.
Donnie Harris
1980 O'Day 23
utchuckd is offline
post #15 of 20 Old 03-13-2014
Group9's Avatar
Check for a small radiator in front of the main radiator. It may already have a transmission cooler. Most one tons come from the factory with one (the one ton we had at work even had a temperature gauge for the transmission on the dashboard).
And, you're right, a one ton should pull just about any boat that will fit on a normal trailer and even some bigger ones. I towed a 26 foot sailboat on a trailer with our one ton (I don't remember the weight, but it had a solid lead keel) on a triple axle trailer, and it barely knew it was back there.
The good thing about heavy trucks like one tons, is that they are usually good buys used, because they are so overbuilt, that unless they were hauling and towing heavy stuff all of the time, they are probably in better mechanical shape than the cosmetics indicate.
utchuckd likes this.
Group9 is offline
post #16 of 20 Old 03-14-2014 Thread Starter
utchuckd's Avatar
Are pads or full length bunks down the side better or worse either way on a trailer?
Donnie Harris
1980 O'Day 23
utchuckd is offline
post #17 of 20 Old 03-14-2014
Hardly a very conclusive test. That could be a power steering cooler, an oil cooler, or the A/C condenser. You really need to check that the radiator has lines going from it to the transmission.
MarkSF is offline
post #18 of 20 Old 03-14-2014
Group9's Avatar
I'm trying to make it easy for the people who didn't take auto mechanics in high school
I should have said, "Look for an extra radiator and then follow the lines."
Group9 is offline
post #19 of 20 Old 03-14-2014
tommays's Avatar
I have towed my J24s all over the place and you do well know there back there
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #20 of 20 Old 03-14-2014
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Pads are fine.. but be sure to stop periodically to make sure they are not backing off. I stopped every hundred miles and would always find one loosening up.
Towing can be strenuous.. not only on the boat and truck.. but on you. Do not be afraid to stop and take a walk around just so you stay refreshed and alert
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
Towing a boat on a trailer m2736185 General Discussion (sailing related) 24 02-26-2013 04:35 PM
Trailer Build Questions boatalec C22 1 10-25-2012 12:46 PM
towing and trailer questions lucianog General Discussion (sailing related) 5 02-03-2010 05:10 PM
Starwind 22 trailer questions WheresTheBrakes Gear & Maintenance 1 11-28-2009 12:41 PM
trailer sailor towing weight comparison chart? arbarnhart Boat Review and Purchase Forum 14 07-26-2007 12:22 AM
