Mystery water in bilge in CAL-29 - Page 2 - SailNet Community
 15Likes
post #11 of 43 Old 01-06-2014
Learning the HARD way...
eherlihy's Avatar
Re: Mystery water in bilge in CAL-29
I noticed a similar problem to Barry's on my O'day 35 (also similar to Barry's ).
The wet exhaust hose that ran from the mixing elbow to the waterlift muffler (one of the few hoses original to the boat) had a longitudinal crack in it where it met the muffler. It looked fine, until I removed it. I would get about gallon every hour of motoring. This hose has since been replaced, and I have added a CO detector to the main cabin.
eherlihy is online now
post #12 of 43 Old 01-06-2014
Lake Superior Sailor's Avatar
I think the water tank is your problem, Mine a Cal 28 is a fiberglass tank with a screwed down top , The seal is caulked . It is under the Vberth , where is yours? ..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #13 of 43 Old 01-06-2014
mitiempo's Avatar
The suggestions on this thread would take a few hours to confirm or deny, if not longer. Determining if it is salt or fresh water can save a lot of time.
Brian
mitiempo is online now
post #14 of 43 Old 01-06-2014
Courtney the Dancer
jrd22's Avatar
Yep, good idea, but absolutely determine if it's ANYWHERE in the plumbing for the head, holding tank, macerator etc, BEFORE tasting it. Don't ask
Faster and captain jack like this.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #15 of 43 Old 01-07-2014
Brewgyver's Avatar
These are all good suggestions. The water tank does seem very likely - it has a vent in the top of it, of course, so having spillage when heeled or rolling is just about unavoidalbe - but you may well be hesitant to taste the bilge water. So, instead, drain most of the water from your tank, maybe filling a couple of gallon jugs to take with you next sail. If you still have water in the bilge afterwards, keep looking at the other suspects.
captain jack likes this.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #16 of 43 Old 01-07-2014
Can't recall.. is the Cal 29 a bolt-on or encapsulated keel?
chrissailorman likes this.
Faster is online now
post #17 of 43 Old 01-07-2014 Thread Starter
Thanks everyone for the thoughts! Good ideas for me to check. The fresh-water usage is definitely something that I do only on big sails so checking the tank for the cause and inspecting the lines from it to the pump to the sink will be some of the first things I check.
Draining it out and seeing if it returns after the next sail might be a good thing.
Keep the ideas coming!
To answer your question, it's an encapsulated keel. No keel bolts for me!
chartscharts is offline
post #18 of 43 Old 01-07-2014
The water under the engine might not be reaching the top of the baffles, at rest. However, what happens when you go sailing and you are healing? The water then slops over the baffles. Result - water in bilge.
My Bristol does this all the time.
MarkofSeaLife likes this.
MarkSF is offline
post #19 of 43 Old 01-07-2014
MarkofSeaLife's Avatar
Dock
Your engine raw water system may have a non return valve vented loop type thing, Vetus make some and they are great however they require peorodic cleaning or they start to ooze water out the drain pipe into the engine bay.
One way to check that, and freshwater cooling system is to put empty plastic bottles under any drain pipes under or around the engine.
Tasting the water will not get you anywhere unless theres a LOT of water. A couple of gallons of fresh water sloshing around the bilge for aweekend will taste like salt, or worse.
Dont go ripping out deck fittings etc until you have done the normal stuff of lose hose clamps, vented loops, etc.
Mark
Bene505 likes this.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #20 of 43 Old 01-09-2014
Glad I found Sailnet
Bene505's Avatar
You could put food dye in the fresh water tanks. Then check the color of the water in the bilge after you sail.
Regards,
Brad
Ajax_MD and captain jack like this.
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
Water in the bilge Dave_E Gear & Maintenance 17 09-09-2013 01:30 PM
yanmar sea water pump mystery silentfaith Diesel 0 10-17-2011 10:24 PM
Bilge Pump Mystery andantesail Gear & Maintenance 19 12-07-2010 04:51 PM
The case of the bilge pump mystery JLBJR Gear & Maintenance 9 12-01-2010 04:59 AM
Bilge water - what's too much Tanley General Discussion (sailing related) 9 06-02-2010 11:36 PM
