Blogs
User Name
Old 04-18-2005
tjgault tjgault is offline
tjgault is on a distinguished road
Boom Vang and Kicker
I have a cruiser/racer and need to install a boom vang.
Can you tell me the benefis of installing a traditional block/tackle vang (with boom kicker) vs. a ridged vang?
Old 04-18-2005
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
Jeff_H will become famous soon enough
I guess I have to ask whether you are in England or one of the other English Commonwealth countries where you would lable a ''Boom kicker'' what we in the States would refer to a boom vang. Otherwise, I am guessing that you are using the term ''Boom kicker'' to refer to the Manufacturer of one kind of semi-rigid vang system. If you are refering to the manufacturer Boomkicker, then the advantages are:
-No moving parts,
-A little less cost,
-Less maintenance,
-Less likely to be bend and therefore knocked out of action at sea.
The downside of a ''boomkicker'', the manufacturer when compared to other semi-rigid vang systems is that it can''t be locked in place so a toping lift is needed once the sail is down. Tension cannot be adjusted. When they break they are shot rather than being rebuildable like many of the more conventional semi-rigid vang systems.
I don not like so called rigid vang systems like the ones made by Spinlock as they are of limited utility and, unlike semi-rigid vang systems cannot be easily used to support the weight of the boom in light but variable conditions.
Display Modes
vB code is On
Boom Kicker Boom Vang dwottavian Gear & Maintenance 2 11-30-2000 01:03 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
