-   -   Ancor wire tracker (http://www.sailnet.com/forums/gear-maintenance/11558-ancor-wire-tracker.html)
Grigrigrigoris 04-20-2005 03:45 PM
Ancor wire tracker
I would like to know if any sailnet member has used the wire tracker to track wires in his boat. I would also like to understand how the thing works.Thank you
Grigoris
Silmaril 04-20-2005 07:37 PM
Ancor wire tracker
I have not used the Ancor unit, but the principle is the same as the one that is used in tel-com to ID wires in a bundle.
You "push a tone" from the tone generator into the wire you want to track. Then using the tone probe, use it''s tip to ID the wire with the tone on it. You hear a warbling tone coming from the probes speaker when the tip touches the wire with the tone on it.
They work pretty well. We use the Progressive model 701 kit in the IT Dept. I run. Costs about $100 and is the industry standard.
But if you have that much wire, and it is old, you may want to think about re-wiring the whole thing. That is what I ended up doing on my 25yo boat. Probably pulled over 500'' of wire out.
Grigrigrigoris 04-22-2005 01:45 PM
Ancor wire tracker
Thank you very much
Grigoris
nmccubbin 04-03-2009 04:45 PM
Wire tracker
Where can I buy the 701 tracker mentioned.
I cannot find it with google.
Thanks
rocinante33 04-05-2009 02:30 AM
Try this wire tracker made by G-B. Cheaper than the Ancor, I think.
Amazon.com: GB - Tools & Testers / Electrical: Home Improvement
raisin56 04-05-2009 07:11 AM
You can Google progressive tone and find it. Go to any electrical supply house in your area, the electricians use them. I have even seen them at Home Depot. The 701K has been the classic standard for years. You need the kit that has a toner and a probe. Here is a link to an online source CDW Product Overview : Tone and Probe Kit 701K Classic - network tool/tester kit hope this helps.
Dan
sailingdog 04-05-2009 07:18 AM
Probably because it isn't "marine". :)
