Here is how I do it with no problems in 30 years. The
shackle pin should have an eye on it. I crank it down as tight as I can get it using a small metal rod or phillips head screw driver for extra leverage. Next I use monel seizing wire and run it through the eye and around the U of the
shackle so that there are three strands. I then use a pair of pliers to twist the the two ends together at the eye and trim off the excess with a pair of dykes.
Some people use a wire tie which is certainly easier, but I am not comfortable with this. Wire ties are subject to UV deterioration and the do not have much strength when twisted. I am probably suffering from old shoolism on this one, but I stick with the tried and true when my boat''s safety is at stake.
