Wiring - Page 2 - SailNet Community
post #11 of 11 Old 05-08-2005
Wiring
The multi-stranded AC wire you have in there is probably ther because that was all the previous owner of your boat could find. The chandlers where I live only carry boat cable with green, white and black - so you can''t really follow the ABYC color rules. The alternative would be to buy three separate wires in the right colors, but I like having that extra layer of insulation boat cable provides for wire that will be moving about inside the mast, and it''s also much less likely to snag or tangle with other wires and halyards in there.
Thermal is offline
rule bilge pump wiring duffyM General Discussion (sailing related) 6 05-27-2008 10:59 AM
In Mast Wiring seapuppy Gear & Maintenance 4 01-09-2005 05:49 PM
Replace Mast Wiring bobrh Gear & Maintenance 1 11-04-2004 04:31 AM
GPS wiring JeffreyG Gear & Maintenance 2 03-23-2001 02:26 PM
Catalina 30 mast wiring ftnjimbo Gear & Maintenance 1 10-15-2000 04:40 PM
