Islander 36 projects in paradise!!!!! - Page 16 - SailNet Community
 176Likes
post #151 of 234 Old 08-24-2014 Thread Starter
christian.hess's Avatar
Re: Islander 36 projects in paradise!!!!!
Originally Posted by desert rat View Post
Way late, very stupid, funny, and cheap pulpit replacement. Have you ever considered a shopping cart with the bottom cut off? roflol.
at this point anything works...honestlt all I need the pulpit for is as a tie up for a flaked sail...as you can see in some of the pics..I still have the toerails to tie it down
honestly I didnt miss it as much as I thought I would...the forestay is your major grab point anyways...
of course this isnt ocean cruising but simply day sailing with a beer in your hand at all times
next week is a big event...baby will be 1 year old...and we will be going on board and daysailing with the family...
then its maybe a trip down the coast to the gulf of fonseca for some mini cruising!!!!!!!!
peace
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #152 of 234 Old 08-24-2014
Christian with a SS welder and 6'' of tubing you can repair the pulpit.
A flat of wood with the same stanchon holes as the boat, take everything to shore.
With a vise you make the ripped up base flat again. Bye Bye chrome coating.
The large section warmed by propane, wear gloves and clamped wooden sleeves on the best section, BEND THE OTHER ONE, in the better direction.
Even bolt the bases on the plank to bend it.
If you end up short an inch or two to weld in, your man has extra.
The welds can be ground invisible.
Never say never!
christian.hess likes this.
sony2000 is offline
post #153 of 234 Old 08-24-2014
islander bahama 24
newhaul's Avatar
For pulpit straight pipes and 45° fittings your man should be able to do something that will work using some of the harder bends salvaged from the damaged one . Should be easy to make something that will work if he has a hacksaw and a welder.
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #154 of 234 Old 08-24-2014
mitiempo's Avatar
Originally Posted by Group9 View Post
I like the lines of Islanders. I had a 1977 Islander 32 that had almost the exact same lines as your boat. A lot of days I wish I still had it!
May have looked similar but different designers. The earliest 32 (1963) was designed by McGlasson. The later ones (1976 & 1977) by Bob Perry. The 36 was designed by Alan Gurney. Quite different profiles.
Group9 and christian.hess like this.
Brian
mitiempo is offline
post #155 of 234 Old 08-25-2014
This one is for sale super cheap in Dorval, Quebec, and doesn't need much to work well.
sony2000 is offline
post #156 of 234 Old 08-25-2014 Thread Starter
if its a 77 mk2 that group had then they are very similar, this 32 was called the baby sister of the 36
http://www.sailboatlistings.com/view/20132
http://www.sailboatlistings.com/view/29729
however it is shoal draft
the older 32 came in 2 versions one with a sprit later named the 34 and the 32.
My previous boat was a old version 34 with baby sprit, and cutaway full keel...
dont know how I got so into islanders but they pick you, not the other way around! jajaja
ECS-IB30 likes this.
post #157 of 234 Old 08-25-2014 Thread Starter
that is the funky spade old style islander 37
http://sailboatdata.com/viewrecord.asp?class_id=1716
post #158 of 234 Old 08-25-2014
first sailed january 2008
northoceanbeach's Avatar
Looks like you've done a LOT of work. Did you buy the boat locally?
northoceanbeach is offline
post #159 of 234 Old 08-25-2014 Thread Starter
yes boat came down from mexico...us.
there are a couple of boats for sale here
including a busted up j35 that smashed against a pier...and is used for daysails
but it has a newish yanmar 3gm and tons of gear
peace
post #160 of 234 Old 08-26-2014
Group9's Avatar
1977 islander out islander sailboat for sale in New York
1977 Islander Islander 32 Mk II sailboat for sale in Maryland
Yep, the 32 Mark II is the model Islander I had. Actually, it's still in my marina, just on a different pier from me.
The coolest thing it had was a dinette table that just came out of the bulkhead and unfolded into the salon. It was completely hidden away when not in use.
The worst thing was the head. I'm 6'3" and 250 pounds, and I could barely squeeze into it.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
Islander 28 vs Islander Bahama 30 vs Irwin Cititation 34 twelch Boat Reviews 42 05-28-2013 11:17 AM
C&C 35' MK II -- Projects Pirate1716 C & C 4 04-13-2009 05:35 PM
Help With Some Projects gpd955 Gear & Maintenance 9 08-02-2006 04:55 PM
