Islander 36 projects in paradise!!!!! - Page 4 - SailNet Community
 176Likes
post #31 of 234 Old 01-25-2014
Maine Dub
34crealock's Avatar
Re: Islander 36 projects in paradise!!!!!
Great job. Maybe you could use the car window tint on the inside of your new windows.
christian.hess likes this.
Al Pickering
PSC 34 #286
Coorie Doon
34crealock is offline
post #32 of 234 Old 01-25-2014
Try mechanically buffing them with 2000 grit sandpaper, 3M rubbing compound for light paint oxidation, or even tooth paste.
sony2000 is offline
post #33 of 234 Old 01-25-2014 Thread Starter
christian.hess's Avatar
the original ports?
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #34 of 234 Old 01-25-2014
rbyham's Avatar
on my plexiglas I used the same thing motorcyclists use on wind screens. Made a great improvement. Comes in 3 levels of grit. I used #2 and #1, Results were more than satisfactory on 1966 plexiglass but kinda wish I had been able to get #3 the heaviest grit. It is a liquid like a rubbing compound but specially formulated for plexiglass. I think it is called Novus.
rbyham is offline
post #35 of 234 Old 01-25-2014
Yep. wet 2000 is the key. Rolite recommends a polisher speed of 1900 rpm for polishing.
sony2000 is offline
post #36 of 234 Old 01-25-2014 Thread Starter
thanks guys the issue with my ports is not the glass part but the flimsy plastic frames that are flimsy and have too many hole from the screws stabbed into them
so they leaked too much
the glass part is actually pretty darn good still as are the 3 lipped gaskets...
wel see what happens...first lets finish the major projects...still have to finish one bulkhead, paint cabin top and smooth cabin sides then vynil the v berth...and then
ELECTRICAL , install davits, solar panel...battery, then its off to find a dinghy! yikes
and then
the engine or motor or whatever! ajajajajaja
so much still to do
post #37 of 234 Old 01-29-2014 Thread Starter
well boats back in the water...
slow progress after that though
here is my main stb bulkhead with backing plate and extra bolts added...notice little jumper strut attachment for the aft lower
post #38 of 234 Old 01-29-2014 Thread Starter
port plate installed...
next is to paint the glass work and trim
post #39 of 234 Old 01-29-2014 Thread Starter
oh I started another thread on my autopilot from way back...
its a cetec benmar ap below deck...huge well built and installed...if anyone has any inout or experience with these Im all ears
here are some pics:
cheers
post #40 of 234 Old 01-29-2014 Thread Starter
oh guys btw I finaly found my through hull depth sounder transducer as I finally have dry bilges...
anywhoo
I spliced the wires as they were cut and the cable is a simple 3 wire cable with a coax type plug for the display
the display is gone...but everything else is SIGNET
are displays intercheangeable these days...????
I would love to simply buy a new depthsounder and use the old transducer and save the new transducer as a spare...
or could I wire up for example a cheap fishfinder display to the current transducer?
thanks guys
Islander 28 vs Islander Bahama 30 vs Irwin Cititation 34 twelch Boat Reviews 42 05-28-2013 11:17 AM
C&C 35' MK II -- Projects Pirate1716 C & C 4 04-13-2009 05:35 PM
Help With Some Projects gpd955 Gear & Maintenance 9 08-02-2006 04:55 PM
